littleblacksmith
irondragon forge & Clay.   Thanks looks like it was a double layup  exactly what I was looking for..
Mudman, nice bottle openers.. I have never made one.. :)
duckcreekforge.  Wonderful work..  I love making rulers or measuring devices..  They are gorgeous..  How thick..
yup. bunch of great work there 58er
Share this post
Link to post
In which gauge system? There are several out there and non-ferrous metals traditionally used a different system than ferrous metals.  It's really best to go decimal inches or metric is you need to nail down a thickness!
if you search on sheet-metal-gauge-chart you will find a number of examples, the  Metal Supermarkets page has a specific ones for brass, copper, several types of steel; but doesn't list what system they are using. exp  for Brass on their system 18 ga   =  .04030
another example to show how different gauge systems can differ:
Gage No. 18                    Size in Inch
Steel Gage                           0.0478
Birmingham Gage (B.G.)    0.0495
Galvanized Sheet Gage       0.0516
Zinc Gage                              0.055
Learned about differing gauges from being in the SCA where one requirement for a helm (Armour) to fight in used to be just listed as 16 gauge till folks ran into differing thicknesses.....
Share this post
Link to post
In the autumn I made a chandelier. I began to make the decor of aged pine on the fireplace in the same style. The work is very dusty, worked on the street. Today frost -15. I had to dress warmly.
Share this post
Link to post
Alexandr,
Congratulations on another beautifull  work.
I know you cannot send me, somehow, your very enviable skills. However, could we come to some agreement with regards to your boots ? This morning was -27 Cº  over here.
Share this post
Link to post
Thanks!
This is the best Russian shoes for winter. Called valenky . Did not find the English name.
Meteorologists promise a further cooling.
Share this post
Link to post
Yes, “valenky” is usually translated as “felt boots”. See, for example, Max Hayward’s English translation of Solzhenitsyn’s One Day in the Life of Ivan Denisovich.
Share this post
Link to post
A couple of weeks ago I posted some twists and an overhand knot in a railroad spike.  I was challenged to make a figure 8 knot.
Challenge accepted.
A figure 8 retrace.
Why do something simple when you can overdo it.
This was mostly work with the tongs and pliers/visegrips. That was good since I had aggravated an old tendon injury in my forearm using a heavy hammer to taper these. This was a chance to get in the shop without much hammering.
I still need to dress it up a bit and tighten the coils.
Share this post
Link to post
My favorite knot is a Carrick Bend for visual effect,  I use a Bowline a lot at work.  I keep thinking about the Scouts in my Troop asking why they needed to know all of these different knots..
Share this post
Link to post
Alexandr,,Im always at aw with your creations, I am curious if the chard beams have a noticeable smoky aroma in the room area
Share this post
Link to post
I would think Chard beams will have a vegetation scent and not have much strength, perhaps charred beams?  (I'm betting autocorrect on that one!0
Share this post
Link to post
Hi All,
New to the forum today.  Today, I wheeled out the tools for working tomorrow.  Thus far I have only created my own tools, propane forge, and a few art pieces from mild steel.  Tomorrow I plan to attempt my first blade from a piece of leaf spring.
Share this post
Link to post
Excellent..  Freezing rain, and super cold here today.. 0 by tonight..  Looking forwards to your knife..
The easy way to do it.. Is you start out with large knot..   Open..
then you grab a come-along and a 2 wire pullers or a solid loop.. in other words some way to grab both ends of the knot..
With a good even heat on the knot..    Pull it closed..    This method is by far the fastest and most accurate why I found..   the only problems is the metal has got to be where you want it to start because once you start pulling you'll have a hard time stopping to re position any of the rods..
Share this post
Link to post
That is similar to the technique I was using to tighten my overhand knot.
For this one, the first knot was not too bad to make. It was trying to weave the second knot and fit the pieces in the forge at the same time that made it challenging.
  I was going to break out the OA torch for some localized heating but wanted to try this using only the forge.
That probably made it harder on myself but I still have a lot to learn.
Share this post
Link to post
It’s too cold to do any forging today, but I did take a minute to siphon the water out of the bosh, to keep the tuyere from freezing. I knew I was saving that old CPAP hose for something!
Share this post
Link to post
The bosh is the reservoir for the water-cooled tuyere on my forge. It’s the vertical part on the left in this photo:
If it were to freeze, the ice expanding could easily pop a weld and make the tuyere leak. We don’t want that.
Share this post
Link to post
Thank you for the quick answer.
My water drum beside the forge is steel. I had installed (too mechanicaly chalendged to do it myself …) a block heater. Took me years to think about it and the village mechanic. No more  winter long emptying a (too) small water bucket and carrying a new supply every morning. It was the emptying that got to me the most ! This  block heater idea might be possible for you as a solution for the colder periods. I have mine on a timer. It heats the water drum (November to April more or less) for 1/2 hour every hour and 1/2.
Since I do not like my steel drum and would prefer a wooden cask, I'll have to see if a block heater can be installed on this. I'll ask the village mechanic who is mechanicaly gifted …
Share this post
Link to post
I know folks who’ve installed water trough heaters in their slack tubs.
I’m not worried about mine as much, as it’s a former beer keg in stainless steel and built to withstand pressure.
Share this post
Link to post
