littleblacksmith
Thank you. I’m not even sure this qualifies as a pattern weld though. I layered a bunch of steel, cut it in thirds and welded it again. Then twisted it a bunch, hammered it back square. Cut it into thirds, stacked it and hammered it into a knife shape. Maybe thats a pattern maybe that a random pattern. One think I noticed was how much steel I wasted with end pieces and grinding.
Share this post
Link to post
On ‎10‎/‎29‎/‎2018 at 9:14 PM, JHCC said:
Certainly:
Thanks for the look at that texturing hammer, John.  I have one too, created with the help of an angle grinder with a thin metal cutting blade. The grooves on yours are much deeper, and I like the coarse effect it produces.
Share this post
Link to post
That’s how I made mine as well. The initial grooves were a little too shallow, so I carved some deeper ones, with the resulting effect you see here.
Share this post
Link to post
RanchmanBen; the multi-bar "Turkish" or "ribbon" damascus swords are certainly considered pattern welded though they have been twisted and then stacked and welded...Not to forget the early medieval blades of Europe, like the Sutton Hoo sword made from stacked and welded twisted bars. (One article on it can be found at: www.ganoksin.com/article/a-replica-of-the-sutton-hoo-sword/)
Share this post
Link to post
Running chrome on windows 10 it worked for me both clicking on it and by copying it and pasting it in the URL spot on a new browser tab.
Not telling us how you are trying to access it makes it hard to troubleshoot.
Share this post
Link to post
Haha Thomas, when it comes to computers I'm pretty ignorant. I believe it's Chrome on a samsung galexy s8 active phone... is that an android thingy?  Most of the time I bumble around till it works or I break it. Should have seen what I've stupidly done to a couple laptops.... there are a few dead ones in my attic.
Share this post
Link to post
same thing happened to me as Das. I copy and paste into chrome (win10) and get a 404 error. i cut and paste the address bar then from chrome and see that there is code (for non standard characters after the letter s in the word sword. www.ganoksin.com/article%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF/a-replica-of-the%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BF-sutton-%EF%BB%BFhoo-s%EF%BB%BF%EF%BB%BFw%EF%BB%BF%EF%BB%BF%EF%BB%BF%EF%BB%BFo%EF%BB%BF%EF%BB%BF%EF%BB%BFrd%EF%BB%BF/
its probably a windows thing.  Das's link works for me
Share this post
Link to post
I made it to a hammer-in last weekend and met a guy who makes hammers. Went to his shop the next day and got to do a lot of firsts for me. I was a striker (to help make me a hammer), while annealing the hammer he showed me how to forge weld a pattern welded billet, and I got to use a power hammer to draw it out after welding. What a great day!
Share this post
Link to post
That does sound like a good day @BryanL
I finally mounted my post vice last night. The hinge plate was made out of mild steel from a repair done sometime earlier in its life, so I welded that straight to the post. Now I can use the vice to make its own brackets for proper mounting. It also needs a new handle and spring......
The base is a feed wheel from a timber processor and weighs close to 100#
Share this post
Link to post
19 hours ago, Helena said:
Also, pretty impressive castings! Great detail
Thank you! It's been a long steep learning curve for me, but I feel like I'm getting close to getting successful casts. These two are blade guards and pins for a couple of chef knives I'm working on.
Share this post
Link to post
Looks like it's a late Columbian and so the whole thing may be mild steel.  Does the plate on the other side look similar?  (How did you decide it was a repair piece?)
Share this post
Link to post
Thomas, the hinge plates are sheared on the back side and the rivets look to be poorly hammered. The nut for the jaws is a scrap piece from some kind of equipment. And the handle is just a rod of mild steel threaded with acorn nuts on the ends. All of this leads me to believe that it was put together with whatever a previous owner had on hand.
Share this post
Link to post
Sheared and riveted was typical for the later Columbians; especially during the war years when finish was lower.  Anything on the back of the stationary jaw?  I had one vise that had the whole Columbian stamping there.
Share this post
Link to post
VaughnT, that’s lovely. Are you working from a laser-, waterjet-, or plasma-cut blank? Or is that getting chiseled out?
Share this post
Link to post
Thank you.  I had these cut for me by Rich Baker over at Plank-n-Ingot. As I understand it, they're plasma cut.
I tried to cut some out by hand, but it was so time-consuming!  I'd have had to charge $200 for each rosette, and I'd likely have gone insane before I was done with the second one!  :O
4 hours ago, 51 Papy said:
Vaughn That is cool!
Thank you.  They're very fun to make.
Share this post
Link to post
