littleblacksmith
Mudman
If you lay a bead of latex calking compound around under the anvil it will deaden the ring even more. I was skeptical about this but tried it on an ear splitting cast steel MP farriers anvil and it's now as quiet as any Fisher or Vulcan.
My wife made this steak turner yesterday. Made out of an old wrought iron RR spike.100_1984.thumb.JPG.be6ff34864dafbc58ce5db0b6cd51ef1.JPG
Share this post
Link to post
Very nice work, Mud.  That's a nice anvil, and I appreciate the extra work you went through to make forged hold downs and angles for the set up.  It looks very professional.
Share this post
Link to post
3 hours ago, Irondragon Forge & Clay said:
That's my plan as well, but I've decided on a bigger stump. There's a guy with a good size piece of Chinese Elm. So I was going to do the same thing, except not screw up this time. Then inset the anvil, and so the silicone.
3 hours ago, VaughnT said:
Thanks,
It was actually Faram's lol. He and I were brainstorming- which I only added 1% valuable input. Then he remembered he had those mounts, and gave them to me .
Share this post
Link to post
Don't forget to band up your stump with thin bands or it will split over time.  One on the top and bottom works just fine, but don't screw them into the wood yet.  I bolted mine together and when I stop having to tighten it at all then I'll know my stump is pretty much not going to shrink anymore.  It's been 2 years and I think I'm just about ready to put the bands on permanently.
Share this post
Link to post
Mudman, that size stump allows you to work close to the anvil, and provides clearance for long items worked over the horns. Try just adding a widewr foot for stability , but I would probably leave it as is.
As to green stumps. Checking and splitting come from drying too fast. If you seal the end grain with wax or paint it dries much slower and less checking/splitting if any occurs.
Share this post
Link to post
Note that changes in ambient humidity will continue to affect air dried wood pretty much forever---at least furniture from king Tutankhamen's tomb is reported to still change with ambient humidity.
Share this post
Link to post
Got some more work done on the razor between swatting mosquitoes today. Quenched and tempered it yesterday, then got it just about ready for scales and honing today. Still a little refinement to do on the tang, but almost there.
(Next to my Tanifuji for size reference)
I actually got the edge centered.
It's right at 1/2 hollow for the grind.
Share this post
Link to post
Thanks Mike! Yep, that's what I used. Gets tricky not to over heat it when it's that thin, but I think it turned out ok. That finish is from a 600 grit trizact belt. Turned out being a very nice satin finish.
Share this post
Link to post
Today was welding, taking the back end of my treadle hammer’s arm from this:
To this:
This has no effect on the hammer while it’s in operation (apart from needing one fewer return spring), but it brings the hammer head higher up and farther out of the way when the pedal is disconnected. This makes regular work at the anvil easier.
Also welded up some bits of pipe and plate onto a tire rim for what will ultimately become a work stand.
Share this post
Link to post
Sfeile, thats turning out great.
Always like seeing whats next John. :)
I've been getting and throwing away these subaru door hinges for a while thinking they would make a cool octopus. Well I tried one as a wall hook. And it hinges for no purpose whatsoever. Cathulu like? Ah well, a good hooky thing. :)
Images are of it screwed into a board.
Share this post
Link to post
I love it.,  it bears an uncanny resemblance to some of my relatives!,
Try Robertson screws  (square drive), instead of the straight screws for a slightly more realistic look for the beast. The centered square 'slot' looks more like a realistic eye,  than the straight slot and Phillips screw heads.
Those superior Robertson screws are usually available in woodworking stores.  They can sometimes be found in some of the big box stores.  (I did buy some at a Home Hardware a while back).
They are,  also,  for sale in any hardware store in Canada where straight slot screws have been substantially supplanted by them.
That screw head was invented in Canada. (patented in 1909, by you guessed it,  Mr. Robertson).  Hence its wide use and popularity in that country.
Boatbuilders also use the Robertson screw.  So boat builders supply sellers should have them too.
Give it a shot.
SLAG.
Share this post
Link to post
Thanks fellas, I'll work on some straps tomorrow. Picked up some 1-1/4 x 1/8 flat stock today, but ended up not having enough. Need to pick up more tomorrow.
Share this post
Link to post
Das, that octopus hook is cool. I thought the 366 Hooks thread just about covered all but you've added another! And I like the slotted screws set vertically. Gives him a surprised look. The head reminds me of the robot in the movie Number 5.
Share this post
Link to post
Thanks Das! That hook is awesome!!
Share this post
Link to post
Thanks Slag, I'll see what I can find. I have only noticed the square drive on decking screws.
Thanks Aus, I have some other hinges to play with. You mean the movie Short Circuit? Or another movie?
Thanks John and Sfeile.
Share this post
Link to post
They have cabinet screws, sheet metal screws, a lot of new electrical stuff is coming with square drive. They are out there, the trick is finding them locally. Some big stores like home depot or lowes, or even an electrical supply house should have something that would work Das.
Share this post
Link to post
Das,
You are welcome.
Searching for a seller of Robertson screws close,  to you is,   probably, the easiest route.
But if that proves too involved/complicated,  mail order is the next best option.
I decided to do a web search for Roberson screws.  (for my own purposes),  and found many sellers.  I used the search term "Roberson screws".
For example,  try www.robertsonscrew.com.
There are many other sellers out there so you have a wide choice of vendors.
Happy hunting!   Pilgrim,
SLAG.
Share this post
Link to post
The razor is excellent and I love the octopus, brilliant stuff.
The forging gods were not with me today, I just couldn't get the metal to move where I wanted it to. I did make a poker for a mate. It's only 6mm round bar, a bit thin to be much good but he finds his 8mm poker too heavy to use. I did my first fire weld too where I bent the tip back to form the rake. It didn't take 100% but I was happy for my first go.
Share this post
Link to post
Thanks Sfeile, Slag. I'll take a look next time im out and if no luck then I'll look online.
Dax, thats a nice twisted handle. Forge welding is kind of like " once you get it, you get it." Keep practicing.
Share this post
Link to post
