Blorph Posted August 31, 2016 Share Posted August 31, 2016 A while back I bought for $65 a forge blower; and have been restoring it ever since. I've been attempting to remove both the grease and rust without power tools (since I'm a broke teenager), with electrolysis and simple green and a wire brush for months now. Here are some of the parts after I've cleaned them up a bit: Funny thing is that I can hardly find any information about the forge blower anywhere on the internet. Perhaps a couple listings on ebay, but that's about it. Gear casing that I just separated today. Any ideas of how I can weld the broken piece back on? Recently removed stand Not sure if I can do electrolysis on this fan. The gear is stuck. By that I mean that I can't get it out, but with the handle attached and the other gear installed, it spins rather well. I just want to get it out along with the worm gear so I can actually remove the grease and rust. This and going to the hardware store (at the start of the school year) are my only two obstacles currently. Also acquiring/building a forge without welding equipment. The stand has a rusty bolt that I was able to loosen a tad bit after doing likely the sketchiest electrolysis cleaning ever with the entire stand in a garbage can with holes in the bottom and double lined with garbage bags. Any suggestions on how I can push out the axle pin on the inner gear or the brass bushings would be wonderful. Rust/Grease removal as well, including information about this particular blower. Quote Link to comment Share on other sites More sharing options...
SReynolds Posted September 15, 2016 Share Posted September 15, 2016 It is not a popular blower. It is the bottom of it's class in terms of their blowers until the Eureka 140. They are the cheapest made in their line-up due to lack of internal machine work such as ball bearings and bushings. Having said that; I use one. As well as the other least inexpensive unit; the Eureka 140. I like them. They work real well. They are not popular as the Midway 70 and 400 were the better made units and more popular. I have never had to take it apart. Thus I'm no help at all. Sorry. I did make a nice pipe adapter for it which I take zero credit for. Most folks jump the wagon in front of the horse and employ duct tape . I guess that is what works best ???? All I done-did was remove that mess and slide-on a two-foot section of 3" exhaust pipe. The end is upset to set another pipe into it. Perfectly suited to slip over the forge blower. An exhaust pipe hanger serves as a clamp. It is worth mentioning that I use it as is. I can't do that with the 400. They are full of ball bearings and require special repair and attention. By the way. Your blower is a "Lancaster" not a no.1 Maybe that will help. Picture of the ad Quote Link to comment Share on other sites More sharing options...
