Rmartin2 Posted June 19, 2016 Share Posted June 19, 2016 Scored this vise at a scrapyard yesterday for $25. I didn't even plan on going, but it was on my way so I decided to do a quick walk through. After going through it I think that the screw washer must have been broken or lost because there were a couple of spacers used on the screw box. One of the spacers looks like it might have been from another vice. I think I will use that one to make the screw washer. There are some stamping on it. It is dated 1867 or 1887 and there is something written beside the date and above that that I cannot make out. I'm sure it's a manufacturer so if anyone can ID this let me know. This is is the best I could do with my phone. The date is visible though. The spacers used on the screw box. The right one looks to be from another vise or tool. Also if anyone has a spare screw washer they would like to sell from a parts vise let me know. Quote Link to comment Share on other sites More sharing options...
matto Posted June 20, 2016 Share Posted June 20, 2016 the right one looks to be more of the origanal than you think. Nice looking vise Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted June 20, 2016 Author Share Posted June 20, 2016 51 minutes ago, matto said: the right one looks to be more of the origanal than you think. Nice looking vise Maybe so but it seems out of place. It fits fine though. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 20, 2016 Share Posted June 20, 2016 Right hand washer is definitely a screw box washer as it has the key for the screwbox protrusion to fit through. Quote Link to comment Share on other sites More sharing options...
b4utoo Posted June 20, 2016 Share Posted June 20, 2016 Unless you are looking just for a original part....do you have a place like "Nutty Bolts" or "Bolts & Fasteners" which specialize just in those things that might have something that might work for you? This could just be obvious...but if not just mentioning it...I had no idea until someone told me about them and they have way out specialty stuff....Just bring them a idea of what you're looking for... Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted June 20, 2016 Author Share Posted June 20, 2016 Something close to original would be very cool, but I don't really see that happening without finding another vise. Making one was my first instinct then I saw some posts about using thrust washers as throw out bearings. We do have some specialty fastener places around and I was on one of their websites looking around. I'm sure I can find something to make it work. Whatever I find will be much better that what the previous owner did without one which is letting the screw bevel create a bevel on the screw hole of the movable jaw. Quote Link to comment Share on other sites More sharing options...
muddawgchuck Posted September 6, 2016 Share Posted September 6, 2016 See you are in Houston, another good spot for finding blacksmithing tools is the Winnie trade days. Cast Iron Cowboy place in the back usually has plenty of overpriced tools but they like to bargain and haggle. Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted September 13, 2016 Author Share Posted September 13, 2016 On September 6, 2016 at 11:06 AM, muddawgchuck said: See you are in Houston, another good spot for finding blacksmithing tools is the Winnie trade days. Cast Iron Cowboy place in the back usually has plenty of overpriced tools but they like to bargain and haggle. I have been to the trade days in Winnie a few times. I have never seen anything spectacular. I will probably head back very soon as I just like flew markets and you really never know what will show up. The best part of Winnie trade days is eating at Al-T's when we are done. Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted April 17, 2018 Author Share Posted April 17, 2018 Wow it’s been a year and a half already? So I decided I would make the bevel washer that should have been in the screw. After a couple of trips to the scrapyard I found a really thick piece of pipe that looked like it would do the trick. I cut a section off and started upsetting it. After some more pounding, cutting, and grinding I wound up with something acceptable. The bevel isn’t perfect but it won’t be putting that pressure directly on the vice face anymore Quote Link to comment Share on other sites More sharing options...
Mark Ling Posted April 20, 2018 Share Posted April 20, 2018 nicely done. What scrapyard in houston was that picked up at? Littleblacksmith Quote Link to comment Share on other sites More sharing options...
Rmartin2 Posted April 20, 2018 Author Share Posted April 20, 2018 Thanks. I really need some more tooling to make this right. It was a scrapyard in Pasadena called L&F. It’s really small but the stock rotates quite often. Quote Link to comment Share on other sites More sharing options...
Dark wing Duck Posted May 17, 2018 Share Posted May 17, 2018 Hi guys The vice looks good. I'm busy with a vice of my own I took a wire brush to it and got all the surface rust off now in wondering with what to treat the metal to keep it nice and rust free? And what type of grease to use in the screw box? Thank you Quote Link to comment Share on other sites More sharing options...
JHCC Posted May 17, 2018 Share Posted May 17, 2018 For the outside, give it a wipe-down with linseed oil, motor oil, automatic transmission fluid, or paste wax. For the screw box, do NOT use grease. Grease is sticky, and you do not want scale, soot, grinder dust, etc getting stuck in there and grinding the threads down. A few drops of a light oil is all you need. Quote Link to comment Share on other sites More sharing options...
