Bmallen77 Posted May 16, 2016 Share Posted May 16, 2016 I recently found this old belt grinder at an electrical surplus shop just sitting on the ground. I bought the thing and brought it home but cannot find any information on this thing. The guy told me at the store he thought it was a 2"x72" belt grinder but I measured the loop around all the wheels and only measured 60"-63" after you let out all the adjustment. Also the two wheels towards the back are both 1-3/4" wide wheels however the bottom wheel in the front where the platten connects is only 1-1/2" is that normal?? The only information on the cast aluminum frame states, "Sandmaster Products Los Angeles California." If anyone has any information on this thing or can answer my questions about the wheel sizes I'd really appreciate it. Quote Link to comment Share on other sites More sharing options...
John McPherson Posted May 16, 2016 Share Posted May 16, 2016 Burr King and others still make 1 1/2" x 60" belt grinders, and stock the belts. Other industrial suppliers carry them as well. Not the most common size, but not totally orphaned either. Killer deal at that price! Quote Link to comment Share on other sites More sharing options...
Bmallen77 Posted May 17, 2016 Author Share Posted May 17, 2016 Thank you I appreciate. It just would be nice to see one all put together like how it came from the manufacturer. I have already encountered some problems where whoever wired the switch on it did not do it properly and in the first test run burned out a $45 3 phase switch. So I'd like to see things like how the platten was mounted, and the rear adjustable wheel that loosens and tightens for switching belts you can tell has been moved back. There is 3 sets of tapped holes where you could mount that rear wheel. And I really am not sure where the right place is. Any ways I appreciate the info. Need to order a couple belts and see how she does. Quote Link to comment Share on other sites More sharing options...
7A749 Posted June 14, 2016 Share Posted June 14, 2016 It's sorta similar to a Burr King I recently acquired. I don't have a platen for it either, but one won't be hard to make. An upright with a 90 deg piece would likely do fine. The cast piece with the slot may swivel back. Take the belt guard off and see where it's connected to the body. It could be that piece is for the table and those two little holes in the wheel guard are where a platen with slotted holes went. Yours is likely just like mine. Note the little bracket with two bolts. That holes the platen behind the belt. The rear wheel shouldn't be a big deal. It may adjust for different size belts. You can try relocating the assembly then measure with a string to see if there's a significant change. As long as it tracks good and the belt stays on I wouldn't sweat it. Once you get the belt on it you should be able to figure out how to put a platen on it. Whatever I make for mine, it will be removable for slack sanding. Quote Link to comment Share on other sites More sharing options...
Bmallen77 Posted June 19, 2016 Author Share Posted June 19, 2016 That thing is awesome looking. What size belt does yours run on it?? Do you know what year your machine is from?? I got mine all up and going. Had to get a new 4 pole switch that cost me $40 but other than that it's been a great little grinder. I got a rear platen built that sits right behind the belt and put a bottom rest for setting your material. It squares up nice and grinds a real clean 90 degree angle. Quote Link to comment Share on other sites More sharing options...
7A749 Posted June 19, 2016 Share Posted June 19, 2016 I haven't done anything with it as of yet. I think it may run a 2 X 60 belt, but I have to measure it. Dunno on the year either. I need to call Burr King about some stuff regarding it and I'll see if I can get a DOM on it when I do. A friend had it and it has been sitting out on his property for quite awhile. He buys and sells machinery too, but on a much bigger scale than me. I have another larger belt grinder I bought awhile back that I'm probably gonna get running first, since it needs less work than the Burr King does. The motor on the BK is an after the fact job and I can't seem to find any wiring schematics on or inside it as of yet and I'm pretty sure it was running on 460 when it was last operating. I'm sort of on the fence if I'm just gonna deal it to someone for what I got in it, I already have two working belt machines as of now and the Ryman I just bought is pretty good sized. I'm real limited on space, so something will have to go or at the very least get moved. If you have some current pics of yours, I would love to see them! Heres that Ryman I bought awhile back. I got it from HGR in Cleveland OH for $180. It runs strong and needs nothing more than a facelift and a reconfiguration to put it on a pedestal stand. The motor is three phase and will run off my rotary for the time being and eventually get a VFD for speed control when funds allow for it. Another reason I like it is because it has a secondary shaft to drive a flap wheel, or whatever else you wanna put on it. Glad you got yours going. Please post pics! Quote Link to comment Share on other sites More sharing options...
Bmallen77 Posted June 26, 2016 Author Share Posted June 26, 2016 Finished grinder Quote Link to comment Share on other sites More sharing options...
Cmig Posted October 11, 2020 Share Posted October 11, 2020 I have one as well I’d love to get some more information on it 1.5 inch belt no idea the power the motor I’m getting a variable frequency drive to run it off to 20 from my house Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted October 11, 2020 Share Posted October 11, 2020 what are you talking about running from 20 from the house? with no location that is hard to even try to guess what that should mean Quote Link to comment Share on other sites More sharing options...
horse Posted October 12, 2020 Share Posted October 12, 2020 220?? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted October 12, 2020 Share Posted October 12, 2020 Looked like a well built grinder. I was wondering if you could switch out the drive and contact wheels for 2" wide ones and so use the easier to obtain belts? Quote Link to comment Share on other sites More sharing options...
