Monoxide Child Posted May 13, 2016 Share Posted May 13, 2016 Ever wonder how when you get burn back when mig welding, the steel wire sometimes melts into the copper tip and renders it useless? Well I experimented and found that you can take any penny from 1982 or older (95% copper) [1983 - present pennies are mostly zinc] and you can weld them to another piece of copper or to mild steel by turning the heat down pretty low and using a cold piece of steel plate as a temperature mediator for the copper because of it's lower melting point. I welded a penny to an 0.35mm tip and once cooled the steel weld took the color of the copper and blended into the copper. I put it in a vice and tried to knock penny off with a shop hammer and it will not break. I use 92% Argon 8% CO2. The question I have is if these two metals mix what is the metal called as a result. If somebody has tried this before please fill me in. I could not break the penny away from the weld. I imagine it has the tensile strength of the copper Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted May 13, 2016 Share Posted May 13, 2016 Yes, copper will alloy with steel in an arc welding environment. It is common practice in the automotive industry to weld the car together with silicon bronze mig wire. Quote Link to comment Share on other sites More sharing options...
John McPherson Posted May 14, 2016 Share Posted May 14, 2016 Technically, what they are doing with cars made of boron steel panels is MIG brazing. More akin to solder or glue than a true welding process. The filler wire serves as a gap filler and bond between the parts. It is not really 'welding' unless you achieve fusion of the base metal with the filler. And boron steel crumbles after welding. Quote Link to comment Share on other sites More sharing options...
Alan Evans Posted May 14, 2016 Share Posted May 14, 2016 I have Tig welded stainless steel to bronze using a 312 rod, seems fine. The only named iron based alloy I can think of is Cor-ten, the so-called weathering steel which gets a bloom of rust which then prevents further corrosion. It is used for sculpture and building facades. Some of the copper alloys have iron in in small quantities to yield influence on the properties and usage. Alan Quote Link to comment Share on other sites More sharing options...
Wroughtnharv Posted June 3, 2016 Share Posted June 3, 2016 Mig welding with silicon bronze wire is the thing to do when welding galvanized materials. It is brazing and the advantage is the minimizing of the zinc fumes created. Production manufacturing of galvanized gates etc is so much easier and safer with the silicon bronze wire. The hiccup is the cost, wire cost more and argon has to be used. Cor-ten is some pretty cool stuff. It's what shipping containers are made of. Quote Link to comment Share on other sites More sharing options...
