Sign in to follow this
Peter Newman
Turkington Treadle Hammer
Hey all,
I thought I would post up some pictures of the treadle Hammer I am using down at Bent River forge.
It is made from a Mobile home axle if you look close at the bottom there is a lever that you can flip once that is flipped you can swing the hammer out of the way if this was your only Anvil or your in a small shop.  The hammer head is about 15lbs.
It's not for sale I am posting up here for the group to have a look at for their own design considerations.
Share this post
Link to post
No my mentor John Turkington did couple of decades ago. I will be replicating it down the road here to make a slightly different one... once  I find a axle that I like.
Share this post
Link to post
I like kicker springs, it lets you use lighter main springs so you get more power for less work and the kicker spring gets the ram moving back up faster. Can it be swung out of the way for hand work? Being able to swing a treadle hammer in and out of the work zone would be sweet.
Share this post
Link to post
Original Post: "if you look close at the bottom there is a lever that you can flip once that is flipped you can swing the hammer out of the way if this was your only Anvil or your in a small shop.  "
Share this post
Link to post
The lever hasn't been moved in years so its pretty froze up at this time. Other wise I would have taken a pic with it moved.
 I if i were to rebuild it the foot would be a tid bit longer.... my face while holding the work and stepping on the leg lever is scary close to the swinging hammer
Share this post
Link to post
Thanks Thomas, I should've looked closer but I distracted myself with the kicker spring.
Share this post
Link to post
5 hours ago, ThomasPowers said:
Yup that 3rd spring really impressed me too once I figured out how it would work.
Yeah, whoever thought of the kicker spring sure was thinking. Bruce Freeman incorporated a version in his Grasshopper treadle hammer though not as elegantly simple as this one. He had his ram and counter springs so balanced it would hold in any position in the stroke,  the kicker was the only thing that made it raise all the way to the stop.
His design got me to thinking about mounting the springs in back and using cable but routing it through an eccentric pully like a compound bow (sort of) so the return springs were at their weakest at the  top and max return at the anvil. No idea if it was workable or practical and never got to experimenting with it.
Share this post
Link to post
Now I'm thinking of how I could put an adjustment on the kicker spring set up so you could "dial it in" for your personal preference...
Share this post
Link to post
Oh yeah, they make turnbuckles for that.
But you want a kicker spring to NOT be in the return or support group, it should only come into play just before impact and start the ram back up, not carry or return it.
Share this post
Link to post
Yes but if you are using tooling you may want to adjust the height the spring takes effect...
Share this post
Link to post
Peter: You need to come down to my shop-just a few miles away in Deadwood Or.. John is old friend of mine-tell him Hi..  One thing you need to realize about his pedal hammers is that he makes them in an afternoon out of whatever junk he has around! No two are alike. Amazingly resourceful man and a great blacksmith.  Give me a call- 541 964 3224. Eric Sprado
Share this post
Link to post
Eric Swing by the shop on Saturdays i am usually there out back from round 9-2 am sure john would like to see ya! He's always looking for someone new or old to heckle ;-) but you know this!
Share this post
Link to post
Peter,
Thanks for the post.  Been thinking about making one of these and the kicker spring idea makes a lot of sense.  Now to find some springs and......
Many thanks
Thomas, did you notice there are 2 chain links on the are where the kicker spring connects?  you could put several on the arm to engage the kicker at different heights for your dies. not as fine an adjustment as a turnbuckle but changing would be faster.
Share this post
Link to post
