Getting Started
I have always been fascinated by blacksmithing and now that I am older and slightly more financially independent, I have decided to take the plunge.
I work at a home improvement store and we have racking made of I-beams. I have already worked out a deal where the next time we replace a damaged one, I can have the old piece. These particular pieces are about six inches tall and 4 feet long, and one end has a roughly half inch plate welded to it. This plate is what I would intend to use as a striking surface.
My idea was to put this beam with the plate up, in a circular concrete form and bury it in concrete with maybe 4 to 6 inches sticking out still.
So how does this sound as a start until I can get a real anvil?
Much worse than just getting a hunk of steel from the scrapyard and MUCH louder too.   Most of your striking surface has nothing under it than air so the true "thickness" is 1/2"  Go to the scrapyard and get a fork lift tine and you have 3-4" and if you use the vertical section you may have 2' of steel under the hammer.
