Randy Griffin Posted March 22, 2020 Share Posted March 22, 2020 I see it now. I'm going to try something a little different and run my tuyere the full length of the trench blowing from the side in order to get a longer hot spot. I'll only use it for heat treating longer pieces. I'll post the results here. Quote Link to comment Share on other sites More sharing options...
pnut Posted March 22, 2020 Share Posted March 22, 2020 3 hours ago, Randy Griffin said: I'll post the results here Please do. I'm interested in how it works out. I'm about to build a new forge. I finally have the okay since I can store it in my vehicle when not in use so it's going to be a MarkIII type of setup I think. Pnut Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 23, 2020 Share Posted March 23, 2020 Or do a variant of my first forge. I had a pipe going along the bottom of a trench with holes drilled in it and the air coming from one end and a ramrod controlling how long an area got air to it. (Steel pulley mounted on a steel rod for the ramrod.) It would be possible to make this with 2 ramrods one from each end and the air supply from the middle of the forge. I made and used this forge in 1981. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted March 24, 2020 Author Share Posted March 24, 2020 Might consider 1” pipe nipples and 1/2” into 1” nipples. Coming in from the side to make charcoal happy. Tho other materials are usable. Quote Link to comment Share on other sites More sharing options...
Old Crew Posted March 31, 2020 Share Posted March 31, 2020 I built an almost Jabod today. I have a bunch of old fire brick that have been laying around my place for at least 10 years . I took an old 2x12 that was 8 foot long and made a 25-1/2 inch square and screwed a piece of scrap plywood on the bottom. Since I had the bricks I lined the sides with bricks to a 10" height from the plywood floor . I used 1-1/4" pipe with a pvc fitting to slide a hair dryer into. The pipe went thru the box at 4-1/2 from the floor . I then filled it partially up with some red clay type soil . It had enough clay in it to pack well. I stuck the page a couple inches past the brick and packed the clay soil around it and formed a shallow trough for the fire. Quote Link to comment Share on other sites More sharing options...
Old Crew Posted March 31, 2020 Share Posted March 31, 2020 The bricks trapped the pipe in place while I packed the clay soil in place and formed the trench. Unfortunately the excitement caused by the ease of construction and the overwhelming desire to have FIRE caused me to forget to take any other build pictures. I started the fire with a little coal that a friend gave me and then put coke on top. From start of build to fire was around an hour. Cost was zero ! I had the old boards and bricks and screws used to assemble it and the dirt. The beginning of the story is it GOT HOT! I cooked some steel to the sparkler stage. The end of the story is I should have done this sooner! That said I am not happy with the size of the "coal bed" or size of the hot spot. I believe that I might need to change the size of the trench some what. Maybe be able to control the air flow from the hair dryer. The fire is super hot right where the air pipe enters the trench and I built it in such a way that I can't move the point of the stock past the hot spot easily. I also believe that the side walls are to tall. The happy thought is that I have 0$ invested in it and a minimal amount of time. So I can modify or rebuild to my hearts content. I will post a couple more pictures tomorrow . With just the dirt in it and also with a fire . I would like any suggestions. Thanks Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 31, 2020 Share Posted March 31, 2020 Think "trough" rather than "pond". I'd cut the sides to allow a long piece to slid across through the hot spot. Most of the space away from the tuyere end is just coal/coke storage as it won't get air. Quote Link to comment Share on other sites More sharing options...
Selph Posted April 14, 2020 Share Posted April 14, 2020 With my bellows and forge dimension test run through, I'm ready to get going on a better setup that isn't just insulating bricks. A few questions though: The adobe mix I've seen is roughly 20-30% clay, with the rest sand. We've got pretty sandy soil, so I'll just dig up some of that for my sand and use kitty litter for the clay. The sand will probably be a little wet since it rained a couple nights ago and has been cold, so from other places in this thread I should probably only add 1-2% of the total weight as water, right? Then let it sit overnight and check in on it in the morning? For the box of dirt itself, is it okay to use some of these cracked insulating bricks to form a structure that I mold the clay over? I figured it would give the wooden frame a bit more space and protection, and since they're cracked, there's not much other use for some of them. Then, do I need to wait for the mix to dry naturally or can I use it right after I'm done forming? Lots of questions, thanks for all the advice so far! Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 15, 2020 Share Posted April 15, 2020 If the sand is wet now it's probably plenty wet. You only want it DAMP enough to pack hard. You don't want to be molding it like modeling clay, you want to have to hammer on it to make it hard. Too much water in soil being compacted starts taking the place of aggregate instead of just lubricating it. Water in mud leaves open spaces between all the aggregate particles as it evaporates so the soil checks or crumbles. JUST enough moisture acts as a lubricant so particles can be forced closer together and when it dries it stays hard. If you use kitty litter you'll need to let it temper over night to dissolve the litter chips so it'll mix and coat the sand to stick it together. Bentonite (AKA Kitty Litter) is NOT adobe clay, it's in another universe. Figure 10% is pushing the upper limit for bentonite content, a LITTLE water will make it into the slimiest mud gravy you've ever seen and it's WAY easier to add a LITTLE more water than it is to try and dry it out adding more kitty litter. Do NOT add water unless it will NOT pack under a mallet. Then just a LITTLE sprinkle of water, mix and let it temper over night and try hammering it again. Hammered hard and you can start a fire almost immediately. If you made mud bentonite can take days or weeks to dry. It's amazing stuff, seriously amazing. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
Selph Posted April 15, 2020 Share Posted April 15, 2020 Oh, okay, great information then. I may have put in too much kitty litter., but I could always add more sand. I just checked on the mixture I currently have and it's definitely a bit dry. It doesn't compact at all when I grab and squeeze it, just kind of crumples apart. I think I'll add maybe another 2 cups of water, mix it in, and wait another day to check on it again. Right now I've got half a 5-gallon-bucket half full of my mixture, so 2 cups shouldn't be too much. I can't really do much with it right now anyway, we're getting our routine April snows right now and it's only 20 out. Quote Link to comment Share on other sites More sharing options...
Bantou Posted April 7, 2021 Share Posted April 7, 2021 Has anybody tried a JABOD with Black Gumbo soil? If so, did it work better a loose fill or dampened down and tamped? The dirt around where I live is all gumbo, which to my understanding is predominantly clay. My concern is that it will crack if I tamp it in instead of loose filling (it cracks like crazy in the Texas heat). However, I don’t have any bricks laying around to form the fire pot on a loose fill. Right now, I either have or can easily scrounge up the other materials I need. Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 7, 2021 Share Posted April 7, 2021 My local dirt is also a heavy clay. I’ve had decent success with mixing in a fair amount of sand. Cracking comes from shrinkage; shrinkage comes from having too much water to start with. If you don’t have access to sand, try adding the dirt and tamping it down without adding any additional moisture. Quote Link to comment Share on other sites More sharing options...
George N. M. Posted April 7, 2021 Share Posted April 7, 2021 Some types or clay absorb water and expand when wet and contract as they dry out. That is why you see mud cracks in dried up puddles, ponds, etc.. So, ideally, you only want as much clay in your sand to bind it together and not enough water to make it expand. It you have a heavy clay soil only add enough water to barely bind it together, no water = no expansion, no expansion = no contraction/cracking. "By hammer and hand all arts do stand." Quote Link to comment Share on other sites More sharing options...
Bantou Posted April 7, 2021 Share Posted April 7, 2021 Thank you JHCC and George. Hopefully I’ll have it up and running by this weekend (with pictures of course). Quote Link to comment Share on other sites More sharing options...
JHCC Posted April 7, 2021 Share Posted April 7, 2021 Always a pleasure. Welcome aboard. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 7, 2021 Share Posted April 7, 2021 Remember that for several thousand years a forge was a simple hole in the ground with no fancy additions. It will work even with cracks! Ash from forging can also be mixed in to make it crack less... For Y1K demos I tend to make a forge from adobe, used to be bricks but is now a hillock in the yard as they weather. I dig up a bucket and take it with me so I can build a forge off the ground based on the Hylestad Stave Church carvings and much easier on my knees. Quote Link to comment Share on other sites More sharing options...
pnut Posted September 18, 2021 Share Posted September 18, 2021 I've been saying I'd post a picture of my MARKIII style jabod when I rebuilt it and here it js. Keep in mind I just threw it together to get the point across. If I was meaning to fire it up I'd make ever level and I still need to cut a little slot for the tuyere to enter at a shallower angle but this is the general idea. Pnut Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted September 21, 2021 Author Share Posted September 21, 2021 Try orientating your trench the other direction with the tuyere coming in from the side. For small forging 2” is deep but honestly 4” is better. Best is about 4” from the top of the tuyere to the top of the hearth with an inch under the tuyere. Then with 4” high sides to the trench to help bank fuel. The sides are not nessisary with coal as you can just mound up coal but with charcoal you just end up with all the fuel a light and not contributing to heating the stock. When I built my steel sideblast I took a 12” square plate and cut it diagonally. Quote Link to comment Share on other sites More sharing options...
pnut Posted September 24, 2021 Share Posted September 24, 2021 Yeah, I did orient the bricks on the bottom the wrong way. I usually have them rotated ninety degrees and have another couple of bricks stacked on the tue side for banking the fuel against. Something was looking off and I couldn't remember what it was hahaha. It had me scratching my head as to why things weren't lining up the way they should. I haven't fired it up in quite a while. My shoulder is feeling better and the weather is starting cooperate so it'll be getting a workout soon. I'll post some pics of it actually running. Pnut Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted February 8, 2022 Share Posted February 8, 2022 My latest mod. my clay has too much sand so doesn’t set up real good. So I tiled the top. I can add brick for more fire. I can use half bricks on back if I need to heat something longer. And a top to hold the heat in. I think that will come in handy when heat treating. prolly build a fire tomorrow. Hope it all works like I’m thinking. Quote Link to comment Share on other sites More sharing options...
pnut Posted February 9, 2022 Share Posted February 9, 2022 Looking forward to seeing a fire in it. Pnut Quote Link to comment Share on other sites More sharing options...
Bantou Posted February 9, 2022 Share Posted February 9, 2022 That is a slick looking JABOD. I’ll be interested to see how the tile holds up. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 9, 2022 Share Posted February 9, 2022 Pretty, do we call it a FBOD? (Fancy Box Of Dirt) I think the tile are a great way of preventing dirt from getting raked into the fire with the coal/charcoal. A clean fire is a good fire. I'd like to see a little of the box above the tiles for a rim though. You know keep extra fuel handy to rake into the fire. Not so high as to get in the way of long stock of course but an inch or so. Nice job, I'll be watching to see how it works for you. Frosty The Lucky. Quote Link to comment Share on other sites More sharing options...
JHCC Posted February 9, 2022 Share Posted February 9, 2022 My coal forge has some big chunks of chimney tile serving a similar function. Definitely good for keeping fuel out of the sand fill. Quote Link to comment Share on other sites More sharing options...
Randy Griffin Posted February 10, 2022 Share Posted February 10, 2022 The tile is holding up good, even with hot metal laying on it. It’s porcelain. I had to do a little more mod to it. If you notice the first couple pictures my tuyere is about half way in the duck nest and I built up clay to cover it. The clay was forcing the air flow straight up and my hot spot was only about 2 inches. I tapered the clay back from the end of the tuyere so the air could flow in all directions. She’s cooking now. I think it’s better than ever. Takes less than 5 minutes from dead cold to steel that’s yellow hot. I haven’t tried with the top on yet but prolly in a few days. Quote Link to comment Share on other sites More sharing options...
