Dave51B Posted August 14, 2015 Share Posted August 14, 2015 Well, guys and gals. Here I go again. I just found out the trade item for my Sept. blacksmith meeting is a "larding needle". I found a couple of post on it here, and have used Google. But geez , how to make one other than sharpen a small pipe and running a rod through for a plunger. As I stated before, my creative juice's are not to juicy......any thoughts.....thanks Dave Quote Link to comment Share on other sites More sharing options...
Glenn Posted August 14, 2015 Share Posted August 14, 2015 A larding needle is a needle which is designed to push fat into meats for cooking in a process known as larding. Larding is a very old technique for keeping meats moist and flavorful during the cooking process, and it continues to be called for in some recipes. Lard is the traditional choice of fat for this cooking technique, since it is cheap and readily available, although other rendered fats may be used as well. A related cooking technique, barding, involves wrapping meats in strips of fat, rather than forcing the fat into the meat.A typical larding needle has a very sharp tip and a hollow body. A strip of fat or lard is forced into the larding needle, and then the needle is pushed through the cut of meat to be larded. As the larding needle passes through the meat, it leaves the strip of fat behind. In a sense, larding could be viewed as a form of artificial marbling, lacing a meat with fat so that it will cook to perfection. Quote Link to comment Share on other sites More sharing options...
yves Posted August 16, 2015 Share Posted August 16, 2015 (edited) Here are the various larding needles used in France and in Nouvelle-France. Reference : Raymond Lecoq, Les Objets de la vie domestique, page 146. Edited August 16, 2015 by yves Give reference Quote Link to comment Share on other sites More sharing options...
KRS Posted August 16, 2015 Share Posted August 16, 2015 A larding needle is a needle which is designed to push fat into meats for cooking in a process known as larding. Larding is a very old technique for keeping meats moist and flavorful during the cooking process, and it continues to be called for in some recipes. Lard is the traditional choice of fat for this cooking technique, since it is cheap and readily available, although other rendered fats may be used as well. A related cooking technique, barding, involves wrapping meats in strips of fat, rather than forcing the fat into the meat.A typical larding needle has a very sharp tip and a hollow body. A strip of fat or lard is forced into the larding needle, and then the needle is pushed through the cut of meat to be larded. As the larding needle passes through the meat, it leaves the strip of fat behind. In a sense, larding could be viewed as a form of artificial marbling, lacing a meat with fat so that it will cook to perfection.+Some cooks use a U-shaped larding needle which works in much the same way as a regular larding needle. Many larding needles also come equipped with small teeth for gripping the piece of fat as it is run through the meat. Cooks can also accomplish larding by injecting lard into a cut of meat with a large-bore needle, as long as they remember to carefully pull the needle out as they force the lard through to avoid making a large deposit of lard in a small area.As larded meats roast, the lard keeps the meat moist and infuses it with flavor. The fat will slowly render out of the meat so that it does not end up tasting greasy or fatty. Since dryness is a major issue with roasted meats for many people, especially large roasts, larding can be a useful kitchen technique to experiment with. Many classic cooking texts such as The Joy of Cooking and the words of Julia Child can help you learn larding techniques.Seasoned fats are popular choices for larding since the seasoning will infuse the meat while it cooks. Lard can be blended with herbs, spices, or ingredients like garlic for a rich time released flavor. By using a larding needle, the cook can ensure that the seasoning penetrates the meat, rather than remaining on the surface as is the case with things like rubs.Source:http://www.wisegeek.com/what-is-a-larding-needle.htm Quote Link to comment Share on other sites More sharing options...
Dave51B Posted August 16, 2015 Author Share Posted August 16, 2015 Hey thanks guys, This about the same thing I've been getting in my search results. I found a few u-tube vids also. I'll figure out something, I guess. Looks like my fullering technique is going to get a workout, or something. So what do ya think, 8 - 10" long? Start with 1/4" round stock? Don't make use spring stock or an old rattail file. I think mild will be just fine,don't you? As always, thanks a bunch....... Dave Quote Link to comment Share on other sites More sharing options...
notownkid Posted August 16, 2015 Share Posted August 16, 2015 Looks like a biopsy tool! We did R & R on some yrs. ago in a shop I worked in, other than it appears Lading puts stuff in not take a piece out! Quote Link to comment Share on other sites More sharing options...
yahoo2 Posted August 17, 2015 Share Posted August 17, 2015 Quote Link to comment Share on other sites More sharing options...
yves Posted September 3, 2015 Share Posted September 3, 2015 Well, guys and gals. Here I go again. I just found out the trade item for my Sept. blacksmith meeting is a "larding needle". I found a couple of post on it here, and have used Google. But geez , how to make one other than sharpen a small pipe and running a rod through for a plunger. As I stated before, my creative juice's are not to juicy......any thoughts.....thanks Dave Have you sold all your larding needles or are there a few left for pics? Quote Link to comment Share on other sites More sharing options...
Dave51B Posted September 4, 2015 Author Share Posted September 4, 2015 Ha Ha, good one yves....I'm still in the" planning stage"....(read ,stalling stage ). Kinda thought I may just follow your lead. Dave Quote Link to comment Share on other sites More sharing options...
yves Posted September 8, 2015 Share Posted September 8, 2015 This week end I could have used a larding needle. I made guinea fowl and i barded them. I would have liked to also lard the legs and the breasts eventhough barding is sufficient. Where are you hiding your needles? Quote Link to comment Share on other sites More sharing options...
Dave51B Posted September 8, 2015 Author Share Posted September 8, 2015 Hiding ? ha.... Haven't even started yet. It's been way hot here, supposed to cool down soon. Then I'll get on it. After all I have till Saturday. Don't want to rush or anything. I'm thinking of starting with a RR spike.....and yes, I'll post pics if it shows up. wish me luck Dave Quote Link to comment Share on other sites More sharing options...
yves Posted September 8, 2015 Share Posted September 8, 2015 Luck and concentration. This is small stuff. Quote Link to comment Share on other sites More sharing options...
Dave51B Posted September 12, 2015 Author Share Posted September 12, 2015 (edited) Pretty lame but.....I give up.....done. After a few attempts at something better. Dave Edited September 12, 2015 by Dave51B Dup pic Quote Link to comment Share on other sites More sharing options...
