First Time forge... yes I'm overthinking it
This is going to be made from a Sink I obtained for free .. the post cap  was 2 bucks and the wood ash, sand ( red sand from property.. natural)  and kitty litter are from property ( or house).  Frame will be from sign holders ( the metal ones you see in yards of houses for sale)  fits sink perfectly and will cut and weld to make legs and support.  Could use lumber from property also .. either way its free stuff.. woo hoo.  So hit me with your comments ..am I on the right track?
Yes I know I misspelled sink..lol  and the firebowl will be formed from the clay. No brake drum etc.
Edited by Craig Tallant
addition
I remembered a conversation you had and spoke about using a bullet tuyer ( or something like that) .. the impression I got was something like what I am doing .. Its a post cap about 1/4 in thick I believe.. Will it be okay to use galvanized steel for the piping underneath ..
Is your cap steel?  If so, soak your galvanized cap in dilute muriatic acid for a few minutes or vinegar overnight to remove the zinc.    A lot of those caps are aluminum and not good for a tuyere, and the acid will eat them anyway.  The piping underneath usually doesn't get hot enough to be a problem.  Use regular black pipe if you can get it, instead.
Edited by arkie
Well I have all the piping put together, used all black pipe .. I am wanting to keep the existing nipple that leads from the sink drain down  .. I have a reducer since it is 1.5 inches and I am using a 2" pipe for the rest of it.  Is that okay?  I could not see a problem with it since it is only about 2-3 inches of pipe at 1.5" that opens up to a drain that is about 3" in diameter does anyone think this will cause complications?
