Adam DesRosiers Posted July 20, 2015 Share Posted July 20, 2015 (edited) Hello fellow forgers! I recently purchased two old hammers. A 400lb Beaudry #11 and a 125lb Bradley Compact. I would be happy to pay for time, copying, and shipping if anyone here has any literature on these hammers. Thanks in advance. Adam. Edited July 20, 2015 by Adam DesRosiers Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted July 20, 2015 Share Posted July 20, 2015 http://www.newenglandblacksmiths.org/power_hammer_info.htm Quote Link to comment Share on other sites More sharing options...
monstermetal Posted July 21, 2015 Share Posted July 21, 2015 Nice score. Not many 400 lb mechanical hammers out in the world. Most everything that can be had is available via Google, Its not much though. Quote Link to comment Share on other sites More sharing options...
beaudry Posted July 21, 2015 Share Posted July 21, 2015 That's a nice pair of hammers to really get some work done.Is that #11a motor driven hammer with the integral cone clutch as opposed to the more common belt driven models with the slack belt and idler wheel setup ?I have a #7 ,200lb. motor driven Beaudry Champion hammer that has been in full time use for about 10 years. I believe it was built about 1924.Some things I've learned to keep it running smoothly;Keep everything well lubricated every few hours at least [ I use Vactra #2 way oil ]I believe the clutch cone gets the necessary lubrication by the oil that seeps out the back of the top main bearing.Keep the main drive belt tight and dressed so there is no slip.The main drive wheel needs to be running at full speed and power when the clutch is engaged for smooth pickup and maximum powerKeep the brake properly adjusted and the brake lining in good shape. I use belt leather glued to the cast iron brake shoe with Gorilla Glue.Make sure there is no slop or looseness in the linkage and the lifting spring for the treadle is adjusted so the brake is engaged as soon as you let up on the treadle.Getting everything in balance takes some time and attention, but it's all out there where you can see it and adjust it.Build a guard around the drive belts with some flat bar and expanded mesh. Make it easily removable with an access door to lubricate the belt tension roller.The motor driven hammers are rare and information is scarce, but there are a few of us around figuring them out and keeping these fine old machines working.Send me a PM and I'll arrange to send you a copy of the original Beaudry factory literature that I have. Quote Link to comment Share on other sites More sharing options...
K A Willey Posted July 21, 2015 Share Posted July 21, 2015 Good info and comments bout adjusting things and about lubricating, Beaudry one thing though the clutch on the motor driven Beaudry Champion hammer is not a cone type clutch, on a hammer that big I have found it beneficial to stop the ram at the top of it stroke when finished forging which it pretty much does on its own because of the counter weight a lot more with the motor driven clutch model than the slack belts, there are a lot of little adjustment to be made but only running the hammer will you find these out. Quote Link to comment Share on other sites More sharing options...
K A Willey Posted July 21, 2015 Share Posted July 21, 2015 Hey beaudry would you pm me. Quote Link to comment Share on other sites More sharing options...
Adam DesRosiers Posted July 27, 2015 Author Share Posted July 27, 2015 Thanks everybody. I've been scouring the interwebs for info, and some of the older posts in this forum have been very helpful. Beaudry, I would be extremely grateful to get whatever info you have. I've had a hard time PMing on here. Also, I know this topic has been covered on this forum before, but I'm going to replace the rubber cushions on the Bradley 125lb compact. Anybody have any fresh info on where to get that done? Quote Link to comment Share on other sites More sharing options...
Adam DesRosiers Posted July 27, 2015 Author Share Posted July 27, 2015 Also, I know this topic has been covered on this forum before, but I'm going to replace the rubber cushions on the Bradley 125lb compact. Anybody have any fresh info on where to get that done? Quote Link to comment Share on other sites More sharing options...
