BifrostFarms Posted July 14, 2015 Posted July 14, 2015 well, for some reason I'm not "authorize do" to post replies on the original post. So..Frank Turley, The farriers pattern came in several patterns. One had half a table, one had the horn, and I don't remember what the others were. I found a manual on this site under "Show Me Your Anvil" if I remember right.Everything Mac, I'm not sure, but based on my 153 lb PW, I'd say it was 100 lb or less.Frosty, Solid fuel. I have access to wood to make my own charcoal if I feel up to that effort. Otherwise (and more likely) I'll buy bituminous. I'm going to use either: 1) a mower deck and brake drum; or 2) a 55 forge ( I have the 55 gal drums). Quote
Frosty Posted July 15, 2015 Posted July 15, 2015 The mower deck brake drum configurations appear sound but the 55 forge is a proven design. Using the second drum for a hood is a good option especially for coal. When you've had some time with coal you won't make as much smoke but it'll still always be a factor.Frosty The Lucky. Quote
BifrostFarms Posted July 16, 2015 Author Posted July 16, 2015 I'll probably go the 55 route then :) Quote
