Cutting Dies for a press
pike3e
Mcraven's shear couldn't be simpler,
2 pieces of blade about 6-8" wide by two feet long. Bottom piece has a hardy tang welded on so it sits vertical atop the anvil.
Top piece is hinged to bottom piece at the top of one end by a stout bolt and a few feet of handle welded on the other end.
Looks like a pair of scissors in operation. Not designed for sole use I don't think, and the cutting action can be assisted by sledge hammer if needed.
The bevel left on the scrap blade is sufficient.
I have a press cutoff tool  that I have cut at least a thousand pieces of 4340 and 4140 off with and my edges are pretty much as sharp as new  It is basically 2 v blocks with stops on both ends that have set screws.  I have a 1" HSS lathe tool bit in each one.  When they eventually get dull I will flip the tool to one of the other corners.  Grant Sarver described this tool a few years ago here and on the NWBA site and I made one.  It has been a great tool.
He mentioned having problems with HSS breaking and he used Cold rolled square 4340 heat treated.  I can't get 4340 square without forging it so and I would then need to get it surface ground.  So I tried the HSS tool bit and it has been great.  He had employees using his and some of them may have used it too cold .
The two cut off surfaces have to be well aligned when cutting thinner steel.  Slightly colder steel actually cuts a little better than really hot if the edges are not perfectly aligned.
Edited by JNewman
A shear doesn't need nor want any more bevel than gives it a little relief. Just enough it doesn't sit flat on the blades is plenty. IIRC 83-85* was a good bevel for metal shears, placed high edges facing of course.
If you can sharpen grader edge it's the cheap stuff but probably good enough. I've found just cleaning up a good smooth torch cut tends to go through grinding disks at an alarming rate unless done at red heat. Then again I salvaged Vascowear from work and the stuff has a lot of tungsten carbide in the 150pt. high alloy steel matrix so it wouldn't just grind off on pavement.
For most things it's more trouble than it's worth.
