Lag bolts
Well, you could buy a tap and die set, and cut em with a die.
If you wanna be old fashioned, they'd twist, then cut with a file.  Another common practice was instead of screws, use a chisel to make little barbs into a spike so they wouldn't back out.
A faster way to cheat is to buy them commercially, then forge the head to the desired decoration (after all, the other part will be in whatever you're making).
I here you about the coatings, I'm a little paranoid about my lungs. I like the twisted square stock like a spiral nail. I want to make some gate hardware and don't want to ruin the look with galvanized hardware. I guess I will buy and modify.
