MadHammerForge Posted February 10, 2015 Share Posted February 10, 2015 I was wondering if anyone out there has put a hood on a charcoal forge,or would know how. Quote Link to comment Share on other sites More sharing options...
njanvilman Posted February 10, 2015 Share Posted February 10, 2015 Is your forge set up inside a building, or outside in the open? Inside, of course you need to move the smoke and CO out of the building. Outside, do you have to deal with wind? Sunshine? To give a better answer, we will need more information about your setup. Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 My forge is setup in a small building where size is a problem. I just want a better way to get smoke out. Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 Has anyone heard of using a wheel barrel body as a hood. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted February 10, 2015 Share Posted February 10, 2015 Talk to your local (wherever that is) sheet metal shop. They may have a hood they are taking out. They can also make one for not much $ You can use a wheel barrow body, unless you are creative, it will also look like a wheel barrow. :) :) Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted February 10, 2015 Share Posted February 10, 2015 Greetings Mad, I suggest you do a little research on hoods on this forum. There are many examples of great hoods and methods of smoke removal and one that just might fit your space.... If it looks like a wheel barrow .... its a wheel barrow... Just my 2c Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 10, 2015 Share Posted February 10, 2015 look into a side sucker hood; they work the same for coal or charcoal; getting the proper diameter chimney is VERY important; as you live in Antarctica you will not have to worry about spark arrestors or rain. Depending on what you do you may even be able to inclose the fire area with a barrel with openings on opposite sides to put work through. Use a wheelbarrow *HOW*??? as a hood horizontally over the fire? Terrible method! Side sucker is much more efficient! However to answer your first post: Yes, Yes. Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 It doesn't need to look fancy it just needs to work. The only reason i had the idea with the wheel Barrel was, because I wanted to save money Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 It doesn't need to look fancy it just needs to work. The only reason i had the idea with the wheel Barrel was, because I wanted to save money. Quote Link to comment Share on other sites More sharing options...
Kal Posted February 10, 2015 Share Posted February 10, 2015 The side sucker is hard to beat. It sits off to one side and doesn't get the the way. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 10, 2015 Share Posted February 10, 2015 It dosnt need to be expensive, the "side sucker" or hoffie style is simply a 12"x 12" box, extending threw the wall with a 12' stack going up 3" above the highest point on the roof. A box or bucket with a hole cut in the side seting next the fire, with a 12' stack going threw the roof works just as well, just cut the hole just about the same square inches as the stack (go smaller and increase till it draws good) going ober the top of the fire makes it hard to see what your doing and get od shapes in the fire. Not to mention it just dosnt seem to draw as well Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 Would a side sucker work with charcoal or would it be to light Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 10, 2015 Share Posted February 10, 2015 Smoke is smoke. The heat from your fire wants to go up, you give it a conveiniant place to go and it will take the smoke with it (and a big gulp of room air with it) some times a wad of pater burt in the stack is neede to get things going. Somthing as simple as 12" ac duct with a 90 degree bend will work to get the smoke away from you, or a 5 gallon steel pail with a hole cut in the side and 12" ac duct coming out the top. Search IfI for "side draft hood" look in the uri hoffie bluprints ans such. The big differences with charcoal and coal are the mass and cleanliness of the fuels (and cokeing, charcoal is "coked" wood) they bothe generate the same amout if heat pound for pound. And generate smoke and hot air. Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 Could this be made from a popcorn tin. Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 10, 2015 Share Posted February 10, 2015 Can you get a 12" flue pipe in the top? Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 10, 2015 Author Share Posted February 10, 2015 I think yes. Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted February 10, 2015 Share Posted February 10, 2015 Greetings Mad, I don't see why not... Good thinkin... It may not last as long but it would function the same... Just for fun deliver it to your forge in the wheel barrow. LOL Forge on and make beautiful things Jim Quote Link to comment Share on other sites More sharing options...
Jim Coke Posted February 10, 2015 Share Posted February 10, 2015 Greetings Mad, I don't see why not... Good thinkin... It may not last as long but it would function the same... Just for fun deliver it to your forge in the wheel barrow. LOL Forge on and make beautiful things Woops double post... Quote Link to comment Share on other sites More sharing options...
Charles R. Stevens Posted February 10, 2015 Share Posted February 10, 2015 A 24 gallon grease drum from your local oil change place will work to. As the top is over 12" its not hard to fit the flue Quote Link to comment Share on other sites More sharing options...
turbo7 Posted February 10, 2015 Share Posted February 10, 2015 or get 1/2 doz 5gal drums mate, do a similar thing with them as the 55gal forge, put 1 or 2 horizontal if you need to go through a window, be aware of fire fleas with charcoal mate, especially if your taking the smoke outside. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 10, 2015 Share Posted February 10, 2015 Note that the side sucker is different than the Hofi variant of it goes straight up from the box. Hofi's works when you don't want to put holes in your roof. My side wall was made from a hail damaged metal roof that conveniently had a large hole where the house's wood stove came through. I just stuck a 10" spiral seamed duct out the hole at a steep angle and it will sing with a good fire! Quote Link to comment Share on other sites More sharing options...
MadHammerForge Posted February 11, 2015 Author Share Posted February 11, 2015 I Made a hood out of popcorn tin last night. It had a decent draw. Some smoke wasn't going up the chimney. I made the hole a little bit bigger to see if that works. Quote Link to comment Share on other sites More sharing options...
norrin_radd Posted February 18, 2015 Share Posted February 18, 2015 I made a hood from a stainless trash can and the back of a smoker I'm using coal but it should work for charcoal I guess. I made a video of it working. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 18, 2015 Share Posted February 18, 2015 Mad; how big is your chimney? and some chimneys need to be "primed" to get the draw started. a crumpled up piece of news paper lit at the bottom of the chimney can encourage it to start the process. Quote Link to comment Share on other sites More sharing options...
