patrick Posted January 22, 2015 Share Posted January 22, 2015 Oil quenching in a plastic bucket with an audience. Link to comment Share on other sites More sharing options...
ausfire Posted January 22, 2015 Share Posted January 22, 2015 Oil quenching in a plastic bucket with an audience. OK. I'l bite. What happened? Link to comment Share on other sites More sharing options...
LastRonin Posted January 22, 2015 Share Posted January 22, 2015 OK. I'l bite. What happened? My guess... flames, melted bucket, more flames spreading... am I close? Link to comment Share on other sites More sharing options...
tompdw Posted January 23, 2015 Share Posted January 23, 2015 Using my arc welder with tennis shoes instead of my boots. Link to comment Share on other sites More sharing options...
Frozenforge Posted January 23, 2015 Share Posted January 23, 2015 Worked at a local exhaust automotive shop in the mid 80s and the whole shop was plumbed with Oxy Acetylene for welding exhaust systems together and for cutting old systems out. Typically when removing an old exhaust system you would torch cut all the hangers then cut the pipe towards the front of the vehicle at which point the system would hang on the rear axle. Making the final cut and instead of it sliding away from me the hot cut end punches me mid chest and leaves a nice cauterized cut requiring 10 or so stitches. Wasn't too bad til the doc had to probe with his finger to make sure there were no punchures into the chest cavity. Of course with the O/A welding overhead we had plenty of sparks, pops and little hot pieces going where you didn't want them to! My favorite was when it went in your ear and as you quickly shook your head you could hear it sizzle Link to comment Share on other sites More sharing options...
winginit Posted January 23, 2015 Share Posted January 23, 2015 Well I wont try to heat the coil springs on my 63 riviera just to lower it a little . LOL live and learn . Once you heat them up that baby drops right on the bump stops a jack stand may have worked . heck that was 30 years ago the right way is take them off and cut one coil at a time . Link to comment Share on other sites More sharing options...
winginit Posted January 23, 2015 Share Posted January 23, 2015 And I will also be more careful flipping up my welding helmet with a hot welding rod in my hand , I stuck that hot sucker right in my ear . I am lucky I did not poke out my ear drum but it felt like I did . Link to comment Share on other sites More sharing options...
Mad Rabbit Posted January 23, 2015 Share Posted January 23, 2015 In high school I was tig welding, using a piece of filler rod. Got done running my bead and went to flip my helmet up. The end of the filler rod was still at an orange heat when I pulled it out of my neck and inch to the side of my wind pipe. Won't be doing that again any time soon. ~The Mad Rabbit Link to comment Share on other sites More sharing options...
Crazy Ivan Posted January 23, 2015 Share Posted January 23, 2015 Similar to that, in high school when I was still learning to weld and before I learned to feed filler wire through my fingers, I used to bump the wire against my chest or stomach to get my hand where I wanted it before I started a new bead....until I bumped the wrong end off my stomach and burned a nice hole in me. I only made that mistake once <_< . Link to comment Share on other sites More sharing options...
mcostello Posted January 24, 2015 Share Posted January 24, 2015 Was drilling a piece of tin while it was setting on My lap. Drill augered on in , with about 1 revolution. You WILL NOT get to see the scar. Link to comment Share on other sites More sharing options...
seldom (dick renker) Posted January 25, 2015 Share Posted January 25, 2015 aw why not :huh: :o Link to comment Share on other sites More sharing options...
Matt_K Posted January 25, 2015 Share Posted January 25, 2015 Was drilling a piece of tin while it was setting on My lap. Drill augered on in , with about 1 revolution. You WILL NOT get to see the scar. Good thing you didn't find your femoral artery. Link to comment Share on other sites More sharing options...
ausfire Posted January 25, 2015 Share Posted January 25, 2015 Was drilling a piece of tin while it was setting on My lap. Drill augered on in , with about 1 revolution. You WILL NOT get to see the scar. My eyes are watering. Link to comment Share on other sites More sharing options...
mcostello Posted January 25, 2015 Share Posted January 25, 2015 At the time was NOT worried about much else. Never thought about collateral damage. Link to comment Share on other sites More sharing options...
Wayne Posted January 25, 2015 Share Posted January 25, 2015 When I was at Doncaster working for IH just before Case bought us, a lad I was working with was setting up a vertical broach. He had the broach at its top point when one of the cutters slipped out of its coupling, by reflex he tried to catch it. The 40lb broaching cutter dropping at speed was half way through his hands before he let go. His hands were ripped to shreds and was a month or so before he was back at work. Link to comment Share on other sites More sharing options...
KYBOY Posted January 25, 2015 Share Posted January 25, 2015 Make sure you got a good hold on a 4 pound chunk of 4150 before you put it under the power hammer..When it whizzes by your head it looks like a meteor coming at you.. Link to comment Share on other sites More sharing options...
KevinJohnsen Posted January 26, 2015 Share Posted January 26, 2015 I'm reminded of my multi meters. Reminded me of something I saw as a teenage kid. Wasn't my fault, but I helped. :) AC repair guy was at our house, our AC unit was blowing the breaker and not running. So the repair guy hooked his brand new 10amp multimeter in series with the motor and told me to run inside and switch on the breaker so he could see how much current it was drawing.... It had been tripping the 30AMP breaker... So I trotted inside, flipped the 30 amp breaker, and it tripped almost instantly, I walked back outside to a very VERY sad looking electrician looking at the smoking ruins of his brand new multimeter... We both learned a lesson that day. Link to comment Share on other sites More sharing options...
Please sign in to comment
