Judson Yaggy Posted January 10, 2015 Share Posted January 10, 2015 What steels would you guys use for pattern welded billets that were intended for non-edge holding applications? For example a door handle, fireplace tool, or vessel. We are looking for good contrast and forgeability here, slicing thru armor not required! I'm more interested in modern alloys than having wrought iron in the mix for the sake of repeatability. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted January 10, 2015 Share Posted January 10, 2015 Nickle/mild steel would be my choice although one of many. Quote Link to comment Share on other sites More sharing options...
Judson Yaggy Posted January 10, 2015 Author Share Posted January 10, 2015 Thanks JM, do you have a specific alloy of Nickel in mind so I can look up the forgeability rating? In response to a PM I just got on this subject I would like to clarify. I've made lots of damascus with higher carbon materials, but for purely ornamental uses am wondering what low C alloys would give a good pattern but still forge easily (closer to mild steel than 1090/L6). Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted January 10, 2015 Share Posted January 10, 2015 Admiral steel list their nickle sheets as 201. I believe there are limits to how many folds and such but for what you are doing I don't think that will be an issue. Looking forward to seeing what you make. Quote Link to comment Share on other sites More sharing options...
pike3e Posted January 10, 2015 Share Posted January 10, 2015 203e and mild steel has nice contrast. Quote Link to comment Share on other sites More sharing options...
Dodge Posted January 10, 2015 Share Posted January 10, 2015 for cheap, there's always banding and band saw. (It makes nice blade material but no law says you gotta make blades... Quote Link to comment Share on other sites More sharing options...
