SJS Posted December 7, 2014 Share Posted December 7, 2014 This is a door handle forged out of a farrier's rasp Quote Link to comment Share on other sites More sharing options...
ausfire Posted December 8, 2014 Share Posted December 8, 2014 Clever. I like how you left the point on the lower end. Clues as to the identity of the original object are essential. Quote Link to comment Share on other sites More sharing options...
yves Posted December 8, 2014 Share Posted December 8, 2014 Might I suggest that you turn it upside down and get the point to ... point upwards. Two reasons : I believe the point, the clue as named by Ausfire would be more readily visible; if I read Plummer well (Colonial wrought Iron, the Sorber Collection), figure 4-74 for instance and I am quite sure I saw the same thing in Sonn, when there is only one decoration it is facing upwards. I am quite aware that you are holding it for the pic. Just mentioning for when you will install it. Have a good day ... or is it night, Yves Quote Link to comment Share on other sites More sharing options...
Frank Turley Posted December 8, 2014 Share Posted December 8, 2014 Most of the old latch handles had a minimum of two holes per 'cusp,' most often three. This was to prevent sideways movement and subsequent loosening over time. Quote Link to comment Share on other sites More sharing options...
SJS Posted December 9, 2014 Author Share Posted December 9, 2014 The handle has a traditional shape to the bow, but the cusps are too plain to be period. Most of the colonial pattern handles had matching cusps, or rarely an elaborately decorated cusp at the top and a pointy cusp at the bottom. Many people pick the handle up and put the point on the top, even though the bow to the handle should indicate that the handle should go the other way. The holes were punch and then drifted square to take a 3/8" carriage bolt, that was how they were mounted to my old 2x6 shop doors back at the farm in Attica. With the handle through bolted it is sturdy enough, unless it is mounted on a slider instead of a hinged door. If I make more I suppose I could punch the cusps for 3 1/2 20 carriage bolts. The texture of the rasp gives it a very interesting visual appeal, and I like making things out of rasps, other than snakes;-) and I have lots of them... Quote Link to comment Share on other sites More sharing options...
ptree Posted December 9, 2014 Share Posted December 9, 2014 I like the hepplewiate style pot holders you made from rasps. Quote Link to comment Share on other sites More sharing options...
