bowens01999 Posted September 27, 2014 Share Posted September 27, 2014 does anyone have any sugestions on how to free up the gears on a blower i just recieved a old forge and the blower is frozen Quote Link to comment Share on other sites More sharing options...
Dabbsterinn Posted September 28, 2014 Share Posted September 28, 2014 well, im not expert in gears or rust things, but what i'd do is i't hit it with a lot of WD-40 or something like that and let it sit for a while, maybe finlube would work better, just any penetrating oil i think, maybe try to move them a little bit while applying it to help getting it between the gears. i'd advise you to wait for some more advice from more experienced people rather than running out right now and do this, but i have a feeling that they'll suggest something similar Quote Link to comment Share on other sites More sharing options...
Stash Posted September 28, 2014 Share Posted September 28, 2014 If you haven't already, pull the top off so you can see the gears- there might be a bunch of gunk/dried grease etc clogging things- clean it all out, and flush the case with solvent. Then start in with some wd40 or penetrating oil and manually work the gears back and forth. Don't force anything- no wacking it with a hammer. I took apart a blower that had some chipped gear teeth, and the bits were wedged in, preventing any movement. Also make sure the fan side is clean- mousies and mud daubers can get in there and clog things up. From that side you can try and shift the fan back and forth, gently. Just work at it easy and use the wd40 etc very liberally, and that should do it for you. Steve Quote Link to comment Share on other sites More sharing options...
JME1149 Posted September 28, 2014 Share Posted September 28, 2014 It would really help if we had a little more information about the blower. Is there a manufacturer's name on it? How big? How old? Pictures would also help us guide you in repairing it. Quote Link to comment Share on other sites More sharing options...
