Can you plate titanium on brass?
TheGreenSmith
I recently been designing a brass part that I would like titanium coated. I chose titanium for its scratch resistance, non-toxicity (can anyone verify?), and its resistance to corrosion. Since the part I am plating is a mouthpiece for an instrument, these qualities are desirable. Side note: for all brass players out there, I will attempt to coat the rim and inside in silver if I can since I know titanium isnt the softest of metals. But back to the original question: can i titanium plate brass and if so how?
I have no idea but my guess is it can't be done.Definitely try a test piece first so you don't ruin your item. Most plating materials are soft like copper. Titanium is hard and highly heat resistant. Plating is a chemical process though so I don't know.
And I was wondering about sputtering as a method of plating.
Now does the price matter? I'd assume most things can be done if you are willing to throw enough cash at them.
Why not gold plating---very non-toxic and inert if you use pure gold and well understood; or just make the item from solid platinum.
I was assuming you are talking about pure Ti and not doing a titanium nitride coating.
  • 1 month later...
