Ser Menalak Posted August 12, 2014 Share Posted August 12, 2014 Hello guys, So I bought a yellow Hobart Leather Welding Apron (770548). I think it's pretty common apron in blacksmithing, it's pretty cheap, on amazon, and is %100 leather. My problem is that when I get working and sweating this runs its yellow dye onto my clothes underneath. Thankfully I wear crappy clothes for blacksmithing and I think it may come out in the wash. It's like I must wear an apron.....to wear an apron. Anyways, I was wondering if you guys have this problem and if you've solved it? I was thinking maybe soaking in cold water or something but I know nothing of leather and it's properties so I don't wanna ruin it. Thanks guys. Quote Link to comment Share on other sites More sharing options...
arkie Posted August 12, 2014 Share Posted August 12, 2014 Some dye experts may wade in here...but with my limited knowledge, some fabrics (not leather) soaked in salt water will set the dyes. Don't know if that would work with leather. Suggest you call a leather store like Tandy or some other. Plain water won't hurt it. If it gets stiff, just run it over the edge of a board. Quote Link to comment Share on other sites More sharing options...
SpankySmith Posted August 12, 2014 Share Posted August 12, 2014 You guys really wear aprons? I tried a full and half apron but found them more bothersome then helpful. I've just resigned myself to a steadily nasty looking set of jeans and t shirts that will never again be their intended color! Plus since it's like 100 degrees with 100% humidity I'd be afraid to add the weight of an apron (and yellow die dripping down my leg? Sooooo not my color.) Quote Link to comment Share on other sites More sharing options...
John McPherson Posted August 12, 2014 Share Posted August 12, 2014 This is a problem that I run into with welding students every semester. When you start classes in August, by November your locker smells like a wet dog, and the dye is on every light shirt you own. You can wash leathers in the kitchen sink, bathtub or a plastic bucket. Very hot water tap water, (as hot as you can stand to keep your hands in), hand dishwashing soap, plain ivory soap, or Woolite only. Rounded end of a broomstick or dowel for an agitator if needed. May take a couple of soaks and rinses to get the dye level down. After the last rinse to get all the suds out, lay the item out flat on an old towel*, roll it up in a jellyroll, and SQUEEZE. Flip it end for end in the towel and do it again. Get another towel, repeat until no more water comes out. Hang it on a line or porch rail to dry. If the item is stiff, chunk it in the dryer on air, NO HEAT, with a couple of clean tennis balls, or even tennis shoes for 20 minutes. *Do not blame me if you use the good "guest" towels and end up in the doghouse, you were warned. Quote Link to comment Share on other sites More sharing options...
Robert Yates Posted August 13, 2014 Share Posted August 13, 2014 Step # 1 ) WASH IT ! with Just any plain wash soap for your washing machine. Step # 2 ) RINSE IT ! with some Snuggle, YES ! I said SNUGGLE Fabric Softener. Step # 3 ) DRY IT ! (LIGHT or NO HEAT) and ADD SOFTENER SHEETS (about 5... Five) to the Dryer with your Leather Item . when it comes out it will be Very Supple,Soft and Ready to use . I have done this for Many years with my Welding Jackets and Aprons and such . should you have a Grease issue Soak the area down with "AWESOME" (Look it UP) it works Very well and will not harm your Washing machine ! NOTE: However Clean Off ALL the Metal Fragments that you can . Happy Living with Leather . Ret, Sgt Robert D. Yates 13 & On Forge Quote Link to comment Share on other sites More sharing options...
Dodge Posted August 13, 2014 Share Posted August 13, 2014 I agree with Robert. I used to wash my welding leathers in the washer. They are the same leather. I didn't do it to wash the dye out but rather the sweat but they were clearly a lighter color after the dryer. I even washed leather gloves! Its been a few years but as I recall, the dyes didn't completely wash out of my white t-shirts right away, but once run through the wash, the leather didn't bleed so bad after. Scott Quote Link to comment Share on other sites More sharing options...
Robert Yates Posted August 14, 2014 Share Posted August 14, 2014 You would be correct Brother Dodge . as Did when I welded a ton back in the day I have owned only three Welding Jackets due to taking care of them so well . Quote Link to comment Share on other sites More sharing options...
John McPherson Posted August 15, 2014 Share Posted August 15, 2014 I have had suede jackets and aprons tear in the washing machine, never had one tear when done by hand. YMMV Quote Link to comment Share on other sites More sharing options...
matto Posted August 15, 2014 Share Posted August 15, 2014 As you use it it will stop bleeding. Some leather gloves do that also. Once they are broke in and used a bit they usually stop bleeding. Quote Link to comment Share on other sites More sharing options...
ytuyuty Posted September 16, 2014 Share Posted September 16, 2014 Seal the leather with an acryilc like Resolene or even acrylic floor wax Quote Link to comment Share on other sites More sharing options...
Robert Yates Posted September 17, 2014 Share Posted September 17, 2014 I will Look up where I have hung my welding Jacket it is well in to the mid 80's when I got it and the jacket shows that Motif of drawings and Painting on the back All done in Acrylic paints & Model Car paints Yes I still wash the same jacket as notoed above when I need to clean it after working with Black Iron and Oil coated steels that leave my welding Jacket very very Black and covered in oil and Metal grindings . I wash out the bulk outside and finish up with the Machine wash and when I get photos posted you will see it is still in very good shape . I have even made very minor repairs to it using Kevlar sowing thread yet it is still Extreamly soft and usable after 20+ years . Photos coming soon . Ret,Sgt. Yates Quote Link to comment Share on other sites More sharing options...
