custom made anvil help
Hello my names Marty I'm a noob and trying to get into blacksmithing I have a couple nice hammers and a friend that works at a machine shop that made me an anvil he makes tooling dies for Timken but he made this anvil from special made tool steel it's called 3311 I can't find any information on it he told me it's similar to 4140 steel but all I want to know is if I should heat treat to harden it or just leave it be and use it how it is the anvil it's self is 5in tall 5.5in wide and 10in long and weighs a good 40-50 lbs if I were to heat treat it would be in a coal forge and cascading water but I need advice and tips please help
post-55418-0-89526600-1405608231_thumb.j
Welcome aboard Marty, glad to have you. If you put your general location in the header you might be surprised how many of the IFI gang live within visiting distance.
Ask your friend about heat treat, he aught to be able to get you the spec sheet. That's a pretty little anvil it's profile is to be expected from someone who doesn't use one. It'll do just fine for now, you'll need to fasten it solidly. I the addiction catches you like it has us you'll be looking for and finding a larger more traditional anvil before long. Once you have a larger anvil in your shop that little beauty will be a PERFECT bench anvil or loaner to someone YOU are in the process of addicting to blacksmithing.
Thank you for your comments. I plan on getting a real anvil eventually but this one was free. And the machinist who made has no smithing experience and this came from 6" round stock so he couldn't do a proper horn with the piece of scrap he had but all in all it has two 90 degree edges and two curved. But The only information that he gave me was that it's called 3311 and it's similar to 4140 Timken makes it specifically for the tooling i don't know if there is a spec sheet for it! So what would anyone else do heat treat or no?
There is definitely a spec sheet. At a minimum find the name of the company which supplied the steel and contact them. There are simply too many variable to offer any advice other than to use it. If the metal you hit on it is hot, it will be much softer than your anvil. Most tool steels are very hard without being hardened anyway.
Making an anvil out of unknown material means - DON'T HARDEN IT!!!  Anvils aren't hard, they have to have some give. If an anvil started to chip and created ricocheting bullets, there would be some VERY HURT people.
Start simple. Use it as it is. If and when you see a problem beginning, you can deal with it at that time.
No need to call google has it.
GRADES OF STEEL
We produce more than 300 standard types of steel in a range of quality levels. In addition, we make more than 450 customized alloy steel grades such as the ones shown below.
The Practical Data for Metallurgists handbook has more information for you – go to the “physical constants – grades of steel” page to learn more.
Carburizing Steel Grades
4120
5120
8620/8720
4720
4320
3310/3311
CBS-600*
CBS-50 Nil*
RESTRICTED HARDENABILITY STEELS
Chemical Composition Ranges
SAE
 No. C Mn Si Ni Cr Mo
15B21RH(1) .17/.22 .80/1.10 .15/.35 ............. ............. .............
15B35RH(1) .33/.38 .80/1.10 .15/.35 ............. ............. .............
3310RH .08/.13 .40/.60 .15/.35 3.25/3.75 1.40/1.75 .............
4027RH .25/.30 .70/.90 .15/.35 ............. ............. .20/.30
4118RH .18/.23 .70/.90 .15/.35 ............. .40/.60 .08/.15
4120RH .18/.23 .90/1.20 .15/.35 ............. .40/.60 .13/.20
4130RH .28/.33 .40/.60 .15/.35 ............. .80/1.10 .15/.25
4140RH .38/.43 .75/1.00 .15/.35 ............. .80/1.10 .15/.25
4145RH .43/.48 .75/1.00 .15/.35 ............. .80/1.10 .15/.25
4161RH .56/.64 .75/1.00 .15/.35 ............. .70/.90 .25/.35
4320RH .17/.22 .45/.65 .15/.35 1.65/2.00 .40/.60 .20/.30
4620RH .17/.22 .45/.65 .15/.35 1.65/2.00 ............. .20/.30
4820RH .18/.23 .50/.70 .15/.35 3.25/3.75 ............. .20/.30
50B40RH(1) .38/.43 .75/1.00 .15/.35 ............. .40/.60 .............
5130RH .28/.33 .70/.90 .15/.35 ............. .80/1.10 .............
5140RH .38/.43 .70/.90 .15/.35 ............. .70/.90 .............
5160RH .56/.64 .75/1.00 .15/.35 ............. .70/.90 .............
8620RH .18/.23 .70/.90 .15/.35 .40/.70 .40/.60 .15/.25
8622RH .20/.25 .70/.90 .15/.35 .40/.70 .40/.60 .15/.25
8720RH .18/.23 .70/.90 .15/.35 .40/.70 .40/.60 .20/.30
8822RH .20/.25 .75/1.00 .15/.35 .40/.70 .40/.60 .30/.40
9310RH .08/.13 .45/.65 .15/.35 3.00/3.50 1.00/1.40 .08/.15
Unless specified: Cu 5 .35 max, Ni 5 .25 max, Cr 5 .20 max, Mo 5 .06 max (1) B 5 .0005 /.003
Hope you did something very special for your friend- that is quite a gift he gave you!
I think most new smiths make some problems with their first anvil- mis-hits, glancing blows, missed materials, etc.
If it were mine I would jut use it as is.
Dave
This grade is not a tool steel. It is a carburizing grade designed for bearings. In its current condition it will be quite soft. To heat treat it effectively you need to have  professional heat treat shop carburize and quench it. I'd think tempering at 450-475F would be about right to get typical anvil hardness.
