New forge in the works!
IRon_FOrgerI22
The "right answer" is what fuel do you have available? If both are available I would suggest solid fuel as it does not go BOOM !! Look at BP0238 Simple Side Blast 55 Forge. It is less then an hour to build and works.
Tell us a little more about this oven you plan to convert to a forge.
What the xxxx am i supposed to do with this oven then Hahahahaha:D
