madwing Posted May 14, 2014 Share Posted May 14, 2014 a friend just gave me a nice 2" square flatter hammerhead. no maker's mark I can see. it's rusty, the face has some roughness, I'd like not to have it marking my work. just use it on stuff I am not to worried about until it is smooth? burnishing wheel until smooth? sand/grind it smooth? then polish it? Quote Link to comment Share on other sites More sharing options...
Dogsoldat Posted May 14, 2014 Share Posted May 14, 2014 Wire wheel it till you can see what you have, all depends on the nature of the marks after that whether it needs a flap disk on an angle grinder or a sanding block, may need a light touch with a file and nothing more. Hard to say what your best approach is without pics. :) Could always use it a little and see just how much transfers Quote Link to comment Share on other sites More sharing options...
madwing Posted May 14, 2014 Author Share Posted May 14, 2014 cheers, using it was going to be my step 1. I am forging with a friend Thursday and we will see what it looks like. but after...make it shine like a brazeal rounding hammer face? Quote Link to comment Share on other sites More sharing options...
John McPherson Posted May 14, 2014 Share Posted May 14, 2014 Flatters are used for taking out hammer marks. So, it really out to be pretty darned smooth and flat. Mirror polish not required. Quote Link to comment Share on other sites More sharing options...
Kal Posted May 14, 2014 Share Posted May 14, 2014 You can clean the rust off with Muratic acid. That's the same stuff they use to clean excess grout from new tile work. Just soak it in the acid for a few hours. Then clean it with water & baking soda. Be sure and do it outside cause the fumes will get ya and tend to cause other things to rust. I was given an old hammer head that had been in a basement crawlspace for years. Once it soaked the rust off I could read the name on it. Of course any pitting will still be there. Quote Link to comment Share on other sites More sharing options...
yves Posted May 14, 2014 Share Posted May 14, 2014 You also get rid of rust with electrolysis. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 14, 2014 Share Posted May 14, 2014 or soaking overnight in vinegar. Quote Link to comment Share on other sites More sharing options...
madwing Posted May 14, 2014 Author Share Posted May 14, 2014 I use evaporust for removal when needed, but it's not in this case...I'll hit it on the debuting wheel at the machine shop at work, then know how to proceed. Flat, no need for mirror, got it! Thanks, all! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 14, 2014 Share Posted May 14, 2014 I prefer to hammer such that I don't need a flatter---I have a 1500 gm swedish cross peen with a smooth rocker face that I can pretty much leave a very good surface ready to file for bright work. I call it my bulldozer and many a student's gnarly first S hook taper has magically become smooth and even from one run with it. However if you have a striker flatters can be a big help Quote Link to comment Share on other sites More sharing options...
caintuckrifle Posted May 14, 2014 Share Posted May 14, 2014 I agree with Thomas the vinegar works very well... Quote Link to comment Share on other sites More sharing options...
Michael Posted May 14, 2014 Share Posted May 14, 2014 Bring it tomorrow, we'll need a flatter for some of the hotcut project we'll be working on and mine is unhandled as yet. Quote Link to comment Share on other sites More sharing options...
madwing Posted May 14, 2014 Author Share Posted May 14, 2014 thomas, i am but a padewan in all this. and it's a cool tool to have and fix up... ;) i hit it with the deburring wheel and there's definitely some texture on the face of it. i will work with it for now, and see how much marking it leaves on a surface so i know what needs to come off. still no maker's mark, and it's a tiny hole for a handle, my guess is thus home-made. michael, i'll bring it, but it's unhandled as well. unless i can carve one tonight. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted May 14, 2014 Share Posted May 14, 2014 If the hole is quite small the original handle may have been made from 1/4" rod stock bent around through the eye and twisted to make a nice handle. Quote Link to comment Share on other sites More sharing options...
madwing Posted May 15, 2014 Author Share Posted May 15, 2014 I wondered about that, Thomas. I think it will work either way...barely for the wood (but hickory is tough stuff ;) ) Quote Link to comment Share on other sites More sharing options...
madwing Posted May 21, 2014 Author Share Posted May 21, 2014 a follow-up: we used this flatter to help finish the forging of a brazeal-style hot cut, and it worked fine, even with the markings. it did break the thin-necked ash handle i carved for it on the fly (michael has a shave horse, and a supply of ash), probably from being tipped up while being hammered flat (thus breaking the handle right at the flatter). i see that, if nothing else, as a reason why that tool would have a rod stock handle, which i am going to make at some point. can anyone suggest pictures of such a handle? Quote Link to comment Share on other sites More sharing options...
