greensngravy Posted March 2, 2014 Share Posted March 2, 2014 I have an old broad axe I was sharpening and found there are some cracks forming parallel to the edge near where it starts to get thin. What is the best way to repair these cracks? Welding? Grounding down past the cracks? Any help would be appreciated. Scott Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted March 2, 2014 Share Posted March 2, 2014 Forge weld on a new edge if you plan to use it. Ignore them if it's just a display piece. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted March 2, 2014 Share Posted March 2, 2014 You might be creating them if using a motor driven grinder. High speed grinding can generate enough heat stress to cause this in high carbon. Quote Link to comment Share on other sites More sharing options...
greensngravy Posted March 2, 2014 Author Share Posted March 2, 2014 Yep, that must be the culprit! using a high-speed grinder. So...I won't do that again on my other broadaxes! I may try the forge welding when I get the guts... Quote Link to comment Share on other sites More sharing options...
