hardie tools?
stowaway
Hey guys, a cave building company stationed near where I work went out of business and auctioned off all of there equipment recently. For a couple bucks I picked up these bits from one of their monster drills. I'm not sure what they're made of but I'm assuming its something hard as xxxx. So I was thinking about turning into tools for my Hardie. Flatten one for a cut off and keep one round for tight radius bends. Its raining in my smithy at the moment so I wont get to fire until Sunday probably, but what are your thoughts?
post-51118-0-79223000-1391792962_thumb.j
You can remove the carbides with a torch or in the forge, they're brazed in so if you over heat it the zinc will burn. Be careful. Then you can forge the steel and make various bottom tools. The steel is tough as can be, the carbides do the cutting but the rest of the bit takes the force, it's good stuff.
We used smaller versions in our drill bits, Kennametal teeth by name. The carbide buttons are useless as anything but what they're made for but the teeth are good tough steel.
Hhmm, maybe I'll try heating one in the forge. Frosty should I just keep it on the verge of burning for a few minutes to let the zinc burn off?
Thanks for all the advice guys, and I think I will keep the one on the right as is for a punch or for small bends.
No, just melt the braze you don't want it to burn. Figure low orange heat will do it, give it a tap on the anvil once it hits orange every once in a while as you let it get hotter. When it reaches brazing temp the button will fall out and you can brush any residual brazing rod out with a wire brush. When I say tap it on the anvil don't use a hammer, just tap the tooth on the anvil with your tongs then put it back if the button doesn't fall out.
Just take your time and it's safe enough, slow and steady wins the race.
