Comadreja Posted January 17, 2014 Posted January 17, 2014 Here you have another just finished:Blade: Forged 5160, 11.5cm long, 3.6cm wide and 0.4cm thick at the ricasso which decreases progressively to the tip. I finished polishing "semi-mirror"Handle: Steel Guard F-114, slice bull horn, aluminum spacer and heart of holly oak. Length 11.5cm.Total length: 22.5cm and weight of 139gr.Photos: regardsJuanma Quote
Rich Hale Posted January 17, 2014 Posted January 17, 2014 Really well done..it has all the style, fit and finish a knife should have...and it is shown in really well taken pictures. Quote
Comadreja Posted January 18, 2014 Author Posted January 18, 2014 Thanks for the comments. Glad you like it Quote
beth Posted January 18, 2014 Posted January 18, 2014 it looks beautiful :) i love the words in your description too - where else would you get "bull horn and heart of holly oak" its so poetic! Quote
Comadreja Posted January 19, 2014 Author Posted January 19, 2014 I am pleased you like it. Thanks for watching. Beth, I don't know, in Spanish sounds quite normal. I think I'll blame the google :D Quote
homeshow Posted January 19, 2014 Posted January 19, 2014 I really like it. What may I ask is your system for heat treat? Quote
Comadreja Posted January 22, 2014 Author Posted January 22, 2014 Glad that you like. To do the heat treatment, I put an iron pipe in the forge. When the tube is hot, put the blade inside. I check the temperature with a magnet, and when reached the antimagnetic point , wait a minute, and Immediately dip the blade into vegetable oil used, approximately 50 ° C. I check the hardness with a file. When the blade is cold, I do three tempered in an electric furnace at 200 ° CI hope you understand, it takes longer to translate the text than to make the knife :D Quote
