David Kailey Posted January 17, 2014 Share Posted January 17, 2014 Angie's Foot Stool Created: 1/16/14 Materials: Black Walnut, Iron, 3/8 round rod Weight: 6 pounds So I was visiting my wife at her work and noticed that Angie, one of the ladies my wife works with, had her feet on top of about a 4" box filled with catalogs of some sort. After asking why, Angie, slightly red in the face told me how she feels more comfortable at times with her feet elevated. Not sure, but this injustice seemed to bug me, most likely the OCD going from 0 to 100, so I said, " I can fix that!!!!" like somekind of low buget super hero. 3 months later!!!!?---- sorry none of my "super hero" powers has anything related to speed. I have a few slabs of 2" and 3.5" black walnut so I cut a 12"x18" block from the 2" slab. I then cut some lengths of 3/8 round bar 10.5" long. 4" from the end of the rod I started to draw the rod out to a taper until it was 6" long. After both tapers where drawn out the rod was 15.5" in length. As my usual habit I textured the full length with heavy hammer blows using the corners of the hammer and horn to drive deep dents in the iron. I know, I know, but I love hammer marks, they are raw, bold, and beautiful. Its my piece so I get to do what I like--------- Hammer that thing!!!!! O yah it happened, just like that!!! Ok,,,,,, to much caffine maybe, moving on...... I then folded the rod in half lining up the ends, bent them at 120 degrees, formed the scrolls together and curved the tips out in lines that flowed nicely. I drove the iron down on to my hardie hole cutter to split the 2 ends apart again, placed it in the vice and bent the scrolled ends away from one another until the lines formed a 45 degree angle that would accommodate the corners of the walnut slab. I created some flat areas, and punched some mounting holes, wire brushed, and treated with bee's wax. Due to the fact that shoes will be placed on the item all the time, I treated the wood like the iron. I melted bee's wax and dripped it all over the wood and used a heat gun to melt it, which allowed the wood to soak up the wax, wiped off the excess, screwed the legs on, a little grinding to get it to sit with no wobbling and a foot stool we have. Angie was very thankful, and put it to use right away! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 17, 2014 Share Posted January 17, 2014 I assume the anvil is *not* part of the item?..... Quote Link to comment Share on other sites More sharing options...
David Kailey Posted January 17, 2014 Author Share Posted January 17, 2014 I assume the anvil is *not* part of the item?..... it is avalible as an add on for $1400 plus shipping. lol Quote Link to comment Share on other sites More sharing options...
scoobshagg Posted January 17, 2014 Share Posted January 17, 2014 That's a very fine foot stool. Quote Link to comment Share on other sites More sharing options...
Camero68 Posted January 17, 2014 Share Posted January 17, 2014 Like it, very nice wood and metal combo. The wood has pretty grains and great hairpin like cool legs. Great job! Quote Link to comment Share on other sites More sharing options...
divermike Posted January 17, 2014 Share Posted January 17, 2014 great story, your willingness to come to the aid of a needy fem now enables you to join the brotherhood of Knight Forgers!! welcome! I dub thee sir stool dropper.....oh wait! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted January 17, 2014 Share Posted January 17, 2014 Hmmm, I'm going to have to make a padded anvil cover for my "sittin anvil" in my shop... Quote Link to comment Share on other sites More sharing options...
LastRonin Posted January 18, 2014 Share Posted January 18, 2014 It looks great. I do have one nit-picky point. The feet of that stool look like they would do a lot of damage to a wood floor or probably even tile. if it isn't carpet or such... is there any way you could add pads to the bottom of them. Quote Link to comment Share on other sites More sharing options...
David Kailey Posted January 26, 2014 Author Share Posted January 26, 2014 It looks great. I do have one nit-picky point. The feet of that stool look like they would do a lot of damage to a wood floor or probably even tile. if it isn't carpet or such... is there any way you could add pads to the bottom of them. It is on carpet. However if pads were needed i would drill and tap holes to screw in a pad and apply felt to the bottom. Or you can mill 50% of the bottom which would give you a 3/8" X 1" area to adhear a felt bad. Quote Link to comment Share on other sites More sharing options...
