2Tim215 Posted December 14, 2013 Share Posted December 14, 2013 I was asked by Scott to do a WIP on my friction folders. I have never done a WIP before so here goes. Hope it helps to explain what not do LOL I have a template for the blade and handle that I cut out of 3mm perspex signage board - here I am only showing the handle template with the blade already ground to shape - I always cut a new handle template if the blade changes slightly coz the center pin hole can move - this way I can make sure the hole is where it must be before I cut the liner material. This shows the G10 liner with holes drilled having made sure that it all fits nicely on the template first. I always use the pre ground blade with the plastic handle template, never a blade template to do this coz when you mark the blade things can move. Liners have been drilled, slab has center hole drilled only. Checking if it all fits in open position Then closed position. Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted December 14, 2013 Author Share Posted December 14, 2013 It's important to note here that it's good to check this with both liners in place to hold the pins in the vertical otherwise they will lean off to one side and this can trow you off. Now I get the liners and slab ready to drill the holes for the blind pins. On this one I haven't decided if it's going to have a solid back piece or just open with pins but the holes usually stay the same. Everything CLEARLY marked and ready to drill Holes about to be drilled at only 1.5mm to 2mm deep Holes drilled - you will note that I haven't yet drilled the back hole for the thru pin - I do this last. Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted December 14, 2013 Author Share Posted December 14, 2013 Liners and slabs sanded true Checking if it all works as plannned Final check before starting the blade grind. I will do a HT on it tomorrow and the grind and etch. You will note that I have changed from using a Corby rivet to one of those fancy fandogo tork pins. This was given to me by a friend after he showed me how to drill the center hole using a rivet drill bit - am going to have to buy one of those as they make life much easier and you end up with a much neater looking knife which makes for a happy client and this leads to more clients so you can pay the bills and so continues the cycle. Will post the rest tomorrow evening and I hope this helps those of you that want to make your own. Quote Link to comment Share on other sites More sharing options...
Old Reliable Posted December 14, 2013 Share Posted December 14, 2013 Forgive my lack of understanding, but why the protrusion on the handle end of the blade? To me it would seem a cleaner blade, at least visually, to not have that piece sticking out when the blade is folded. But then I am in no way a blacksmith, let alone a bladesmith, so there might well be a reason to it. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted December 14, 2013 Share Posted December 14, 2013 A long time ago they didn't use springs. The protrusion is the stop. Since the only thing keeping the blade from swinging freely is friction, thus friction folder. This style of knife really doesn't lend itself to being kept in the pocket, usually a belt sheath is used. Done properly, they can be quite eligant. Look forward to seeing this knife finished! Quote Link to comment Share on other sites More sharing options...
BM454 Posted December 14, 2013 Share Posted December 14, 2013 Thank you very much Tim. Although now I'm going to have to try my hand at it. Looks great my friend. Quote Link to comment Share on other sites More sharing options...
windancer Posted December 14, 2013 Share Posted December 14, 2013 I have been hankering to do a friction folder for several months. Thanks for doing this and nearly elimination my learning curve bumbling around on my own. Good job! Dave Quote Link to comment Share on other sites More sharing options...
Stephen Olivo Posted December 14, 2013 Share Posted December 14, 2013 Thanks for doing this. Always interesting to see how someone works. Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted December 14, 2013 Author Share Posted December 14, 2013 Thanks all, only a pleasure. Will try have the finished knife up tomorrow. Quote Link to comment Share on other sites More sharing options...
2Tim215 Posted December 16, 2013 Author Share Posted December 16, 2013 Finished, packaged and about to be collected. Hope you enjoyed. Quote Link to comment Share on other sites More sharing options...
windancer Posted December 16, 2013 Share Posted December 16, 2013 Very, very nice work! Again, thank you for taking the time for this how-to. Dave Quote Link to comment Share on other sites More sharing options...
Loneforge Posted December 18, 2013 Share Posted December 18, 2013 Cool Thanks Quote Link to comment Share on other sites More sharing options...
aquamanlr Posted January 23, 2014 Share Posted January 23, 2014 Very good WIP. I like the use of basic parts and design of your knife. LeeRoy Quote Link to comment Share on other sites More sharing options...
