Glenn
Blacksmithing gems and pearls
Note to self keep the cows out of the shop because you have to wait for the pies to dry before you can pick them up.  OK got it.  I'll remember it now.   Ed
Share this post
Link to post
3 hours ago, ThomasPowers said:
naw; just run them by the gas forge twice and serve!
And if you're distilling your own you can use dry cow pies to smoke dry your malted barley instead of peat for that unique NM flavor Scotch.
Share this post
Link to post
It's the little details that are so important---like you are supposed to use birch *twigs* when you sauna---not *trunks*!
Share this post
Link to post
On 1/6/2016 at 6:52 PM, SmoothBore said:
A long time ago, I began to realize there are many, many things you can do, ... and a much smaller number of things you should do .....
The trick is in knowing which is which.
From SmoothBore
fantastic advice, but i probably wont listen to it for a while. I am still young and need to do all the stupid teenager stuff still. :P
Share this post
Link to post
Much more fun to make new and improved mistakes than to repeat ones *everyone* knows about....
Share this post
Link to post
Improved mistakes - That is a good one Hope you do not mind if I add it to my vocabulary :D
Share this post
Link to post
Not at all.  After all English is a language that is known for pushing other languages into dark alleys and walloping them and then going through their pockets for loose grammar...
Share this post
Link to post
So true Thomas and it keeps leaving the alleys the living language.
Share this post
Link to post
A 60 year old blacksmith has things to do the lifting for him/er.
Share this post
Link to post
Frosty is that lifting device called an apprentice?
A 250 pound anvil wants to live where it was placed, the second time.
Strap or tie a board, pipe, etc across the top of the anvil make it weigh only half as much if two people are lifting the thing. If one person is doing the lifting, then it becomes a lift, crib, go to the other end of the board, lift, crib, and repeat as needed. After you use this method a time or two, engine hoists are not that expensive (grin).
Share this post
Link to post
I believe you can move a 250 pound anvil faster the second time if you placed it on your foot the first time! :D
Share this post
Link to post
Apprentice, student, neighborhood teenager, anybody ELSE, you betcha. A garage sale engine hoist was one of the best $50.00 I've spent.
Share this post
Link to post
I use my small excavator. The smithy is built so the arm can reach in. Should I nickname it 'Apprentice'? It needs some training before it an use a sledgehammer.
Share this post
Link to post
Got sick of waiting for my son to show up to help change the stump under my 213 lb PW, so after 2 weekends I brought my forks up from the other farm put them on bucket of tractor, moved the anvil up to just inside the rolling door, adjusted the forks, picked the anvil off old stump placed the new one under it and bolted it down.  Only problem I had was the flat tire on the handtruck used to move the stump and anvil back where it belongs, had to stop in mid stream and get the jump kit with compressor, moved a lot easier with 2 round tires.
Share this post
Link to post
Most of my chain tends to be scrap yard or side of the road finds---the infamous "carry-iron" that even vultures won't touch!   Thomas Powers
Share this post
Link to post
