jimbob Posted September 5, 2007 Share Posted September 5, 2007 :confused: On Blueprint #503; about Forging Lubricants; its talking about alkaline salt as a lubricant instead of table salt...I give up what is "Alkline salt" also could you mix it with Molybdenym and get and even better lube??? Quote Link to comment Share on other sites More sharing options...
Glenn Posted September 5, 2007 Share Posted September 5, 2007 The "alkaline salt" referred to in the Blueprint is an industrial lubricant that we sell on IForgeIron.com. The smallest package of this lube is $5.00 plus shipping. This mixes up to a working volume of material that you can actually use, and is not just a sample. The lube can be used straight or it can be heavily diluted and applied as a spray to the hot punch or drift. Quote Link to comment Share on other sites More sharing options...
jimbob Posted September 5, 2007 Author Share Posted September 5, 2007 thanks I'll check that out ...what about mixing Moly with it? tired the store button get 404 not found them it take you to main page and only books are listed Quote Link to comment Share on other sites More sharing options...
