Fullering Tool Die Material
I assume this is a guillotine filler and not a swing arm fullering tool?
Go with leaf spring material and I sure hope you made the tool to fit the commonly available die material and NOT made the tool first and then are hunting something that fits it---that way tends to be MUCH more *expensive*!
Thanks Guys, I found a large truck leaf spring that will work perfect. I have enough length to make three sets of different styles. I did already make the tool and just needed the die material. I made it very heavy duty out of 1/2 inch plate steel and welded it together after I milled the slots down the side. I ordered some mill cutters for my radius and will machine them when the cutters arrive. I will post a picture when complete.
I did allow .020 inch clearance on the sides when I milled the steel for side and face clearance so it should not stick. It actually feels a little too sloppy right now. I will try to mill the new leaf spring dies so I have .010 inch clearance and tighten up the slop.
Thanks for the advice, I appreciate it. Being new to this I appreciate all the help you guys can give me.
Ron
Looks good. Building one of these is on my project list for the winter when work is slow and it's too nasty outside to work, That will give me some time to play with my small mill.
The one down side I see to your design vs the design I've used in class is that there's no way to fuller the long way with this set up, such as if you wanted to fuller the length on a blade. The commercial design had a C shape to the frame so you could come in from the side if need be.
