jeep4x4greg Posted August 31, 2007 Share Posted August 31, 2007 I got a few hardies in the big lot of stuff i got last weekend. my anvil has a 3/4" hardy hole, but most of the hardies are for a larger hole. any reason i can't/shouldn't take a grinder to them and thin them out to the 3/4" i need ? I cant think of anything that would make this a bad idea, but i might be missing something. let me know your thoughts :) Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 31, 2007 Share Posted August 31, 2007 I'd suggest doing it only on an as needed basis as you may end up with an anvil with a larger hardy hole in it someday---and why waste the time if you don't need to use that particular hardy tool. Quote Link to comment Share on other sites More sharing options...
MLMartin Posted August 31, 2007 Share Posted August 31, 2007 if ya do grind them make sure not to grind to much without cooling the hardy or you will heat the hardy tool and loose your temper on the tool Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted August 31, 2007 Share Posted August 31, 2007 basically the only hardy tools that are hardened to any degree are the cold and hot cuts, the bases or shanks on those are normally not hardened. Find you a stump somewhere and make a stake plate for the top with the right size hole in it and fasten it down to the top of the stump next to your anvil. Quote Link to comment Share on other sites More sharing options...
