New armour piece
Razzputin
  • 2 weeks later...
I do Not know about "Galvanized spring steel" However they look about like a (Aluminum washer) and at Best they Could Be Galvanized coated washers however they are not Rough enough for " Galvanized spring steel" as to what I have ever seen or Bought, I have used them before in mechanic work , the military and civilian as well ! What does the single gantlet weigh in pound or oz 's sir ?
Sam
These are spring washers bought from a hardware store and are definitely spring steel and not Alu, it weighs 2.2 lb. I made a shirt from the same material which weighs in at 14 kg which ill create a new post on later on today as well as the coif I made also from the same material which is 4 kg.
Here is my final outfit, you can see the bracer with its glove on my right hand. It has leather underneath it which prevents it from sliding up and down my arm, and it is fastened with a leather string that is woven into the two loose sides.
  • 9 months later...
