pijamak Posted July 24, 2013 Share Posted July 24, 2013 Hey guys, I'm still pretty new to blacksmithing, and I have my modest shop setup outdoors... This last few weeks the weather's been great, not a single cloud in the sky and it's bright and sunny until 9pm. Whenever I'm working at a friends shop (indoors... and sort of gloomy), I can control the temperature very well, I can get to welding white without burning the mild steel (most times :P )... but while working under the sun, It's crazy different, I burn the metal all the time, and it's impossible to weld decently since the "white" hot looks orange! any tips on how can I deal with that? sunglasses help? or is it only a matter of getting used to that? Thanks! Link to comment Share on other sites More sharing options...
toolish Posted July 24, 2013 Share Posted July 24, 2013 Think you have to work on some sort of sun shade for your fire. Just need to find a way of casting shadow on you forge, thousand different ways you could do it, depends on your set up. You may also need to get the sun out of your eyes as well to make it easier for you to watch the forge. There is a reason why historically the blacksmith was always in a dark and gloomy looking shanty on the outskirts of town. Link to comment Share on other sites More sharing options...
swedefiddle Posted July 24, 2013 Share Posted July 24, 2013 Good Morning, Patience is a hard teacher. Learn well, GrassHopper. Make a temporary roof tarp, preferably dark tarp to stop the glare. Welding is a balance of temperature and pressure. It is possible to weld with a hydraulic press, at a lower temperature than welding with a hammer. If you are trying to make consistant welds, work in a consistant environment using a consistant procedure. Bouncing around to work in the sunshine is not a step forward. Been there, Done that, Still do. Neil Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2013 Share Posted July 24, 2013 crossing the prairie by wagon smiths used to support an empty barrel in the air and thrust their metal into that to see the true colour. Of course using real wrought iron they had more leeway as it positively loves temps that burn up modern steels. Link to comment Share on other sites More sharing options...
Frosty Posted July 24, 2013 Share Posted July 24, 2013 Forging in sunlight is a trick it takes time to train your eye to. Given time you learn to judge but it's always iffier. A shadow box is a better bet, a bucket painted black inside works a treat. I've thought about opening both ends of a bucket and laying it so I could see the fire through it and hopefully it'd make judging heat easier. It's easier with a gas forge than solid fuel but no easy feat regardless. Frosty The Lucky! Link to comment Share on other sites More sharing options...
ThomasPowers Posted July 24, 2013 Share Posted July 24, 2013 let's not forget standing so your shadow is on the face of the anvil too! Link to comment Share on other sites More sharing options...
pijamak Posted July 25, 2013 Author Share Posted July 25, 2013 thanks for the tips guys! I'll try to set up some shadow and get a dark bucket :) Link to comment Share on other sites More sharing options...
toolish Posted July 25, 2013 Share Posted July 25, 2013 I'll try to set up some shadow and get a dark bucket :) Wait and see how long it takes you to melt a hole in the bucket with a hot bit of metal, which will annoy you to tears lol Link to comment Share on other sites More sharing options...
Glenn Posted July 25, 2013 Share Posted July 25, 2013 Lessons in Blacksmithing Seeing Colors That are 12 levels of heat. If you divide 100% by 12 that is 8% repeatability at each heat level, or about 150-200 *F This is good information of seeing colors. Outside in the sunlight you can shift the colors by one, two or more levels. Link to comment Share on other sites More sharing options...
Dan C Posted July 25, 2013 Share Posted July 25, 2013 If you had a side draft chimney similar to what Bigred made for his forge in this thread, depending on where the sun was it would offer some shade. '?do=embed' frameborder='0' data-embedContent>> Link to comment Share on other sites More sharing options...
Private Entrance Posted July 29, 2013 Share Posted July 29, 2013 I have the same problem (I'm working on rigging a sun shade. Need to figure out how to do it without making it an eyesore). In the meantime, I wear a pretty wide brimmed straw hat, like a lifeguard's hat. Helps a lot with casting a broader shadow over the fire when I want to take a look at the color of something. Not perfect, but works much better than trying to guess in broad daylight. Link to comment Share on other sites More sharing options...
Please sign in to comment
