Dabbsterinn Posted June 25, 2013 Share Posted June 25, 2013 so, im not quite done with this one, but i'd still like to show you what i've done so this is my attempt at a broken-back seax, i fear it's a bit too long, about 2.5 feet , it's completely blunt because it's intended to be used in the fighting in the viking group with my> axe. im thinking about either just finishing driving the handle up on the handle, i haven't managed to do that yet because i took my vice up to my smithy last Monday because the new one my brother made for me wasn't working, so i didn't have one here at home to finish the handle, but im going there soon to take pictures of my smithy and clean up some knives i found lying around here, im also thinking about putting a pommel on it if the tang is long enough, i'd probably make it from one of our sea-fishing sinkers, im though unfamiliar with working with lead, but i doubt it will be much of a problem, Quote Link to comment Share on other sites More sharing options...
Hyper Iron Posted July 1, 2013 Share Posted July 1, 2013 Don't mess with the lead. It's way to soft for a pommel. And what's worse its quite bad for you. Plus it melts at just over 600*F if memory serves. You might want to just do a simple wooden handle. With pins going through it. How think is that blade? Quote Link to comment Share on other sites More sharing options...
Dabbsterinn Posted August 3, 2013 Author Share Posted August 3, 2013 i actually scrapped that idea of using this entire thing, i just took it in half and made a knife out of the tip and some freestyle short sword/ large dagger thing, it kinda resembles a gladius, out of the bottom one Quote Link to comment Share on other sites More sharing options...
BlacksmithDrew Posted September 8, 2013 Share Posted September 8, 2013 Doesn't look bad, how's the dagger now? And I normally make my handles with a leather grip. Gives it a better hold when you use it. Quote Link to comment Share on other sites More sharing options...
Dabbsterinn Posted November 14, 2013 Author Share Posted November 14, 2013 the dagger is almost complete, i'll post pictures of it when i remember taking it home with me from my smithy, and you are right, leather does give good grip, but i prefer the bark, mostly because i don't have access to leather Quote Link to comment Share on other sites More sharing options...
sfDuck Posted November 15, 2013 Share Posted November 15, 2013 I think you made the right decision , by making two. As for the slipping wooden handle using a full tang is fine as you can use a braided wire that goes through the hole in the handle to fasten the braid to . The outside of the handle the braid can round the handle at an angle or flush together ,copper or silver add a niece touch. Quote Link to comment Share on other sites More sharing options...
