hydralic ram shafts as a source for tools material?
I was recently offered discarded hydraulic ram shafts for use in blacksmithing.  They range up to 3 inches in diameter and the length is described as long as you want up to several feet.  Is this steel suitable for making hammers or other tools or maybe a small cone mandrel to use in a hardy hole.  The metal is free so I will likely take it even if its too soft for a hammer then find a use for it later.  I have been told it is chrome on the outside but softer in the center.  Is this likely to be high carbon steel or mild?
I don't know about the quality of the steel, but I hear chromium poses a serious risk of heavy metal poisoning.  I wish I had more details on it than that, but I'm sure someone else will pop in and fill in the blanks, I'd like to know the specific hazards myself. I imagine most people that would explain further are probably more qualified than Wikipedia, just by virtue of experience.
The chrome is a problem to watch for.
In general the material for chrome rod base material is 1045 or 4140. At lest is is here in Australia. If you have a lathe you could machine the chrome off, instead of grinding or burning.
Just grind it off, but be safe about that...using good grinding practices. If you are afraid of the particals install a fan to help blow away the airborn stuff. DO not breath chrome or zinc in any form.
Be glad you have a source of free material.
Carry on
I would NOT grind the chrome to remove it, use a lathe. Grinding puts chrome dust into the air and it settles onto surrounding materials to be picked up and made airborne again.
Yes we sometimes go to the last decimal point in safety.
But would you rather be safe or suffer the rest of your life?
  • 3 weeks later...
