latches and drop bolts
ironman186
Hi All
A re post ,but in a different category , I am working on a set of gates ,more like doors in a sense
more vertical then horizontal in shape .I have only had one set of gates galvanized in the past ,and
when I received them back ,the latches and drop bolts were stuck ,thanks to being dipped .A no
brainer I guess . So how do I avoid this again ? Use stainless and attach after dipping ?
Any ideas .Photos would be great .I could use a little guidance if any one has experience in this department . Thanks for your replies  :rolleyes:
Can you have it electro plated? It's much cleaner and I think, better looking. You'll probably have to have it plated in separate pieces and do a finish cleanup of hinges, pintles, bolts, etc. before assembling.
