Suspicious Columbian?
With the C/triangle, looks to me like a Columbian.
Does that look like a weld line at the waist to you?
I haven't seen it in person, this is just a CL  photo.
Columbians were cast steel- no reason for there to be a weld line there unless it was once broken off at the waist?
3I13L13F15I55Gb5K7d5h261e665bf0f61e24.jp
Honestly I can't tell anything from your picture. I doubt that a Colombian anvil would be broken at the waist when the rest of it looks to be in pretty good shape.
Molds, for any cast product, have a limited life and can become mis-shapen over time/use. I guess until you see it in person, its going to be impossible to determine if it
was broken.Could also be a West anvil?
Or it could have been a ship's anvil. I have seen a few that had been cut at the waist and welded down some where aboard a ship. Then when no longer needed rewelded to the same or a different base after retirement.
However I think that Jim is probably right since the joint is such a good fit and the weld really neat and well done. Most of the ships anvil re-welds that I have seen look pretty scabby and ill-fitted.
Greetings again Blackfrog,
To my knowledge Trenton or Columbus Forge and Iron made anvils for a lot of hardwares and suppliers..  The belt line weld one were after the 30s...  I have a few with belt line welds one 500 pounder..   I also have one marked Derby..  To my knowledge Columbian were cast and did not belt line weld...
More pictures and I might be able to help more
Forge on    Jim
DId you buy it?
Yes I did.
After looking closer at it, I didn't want to let it slip by.
Just got home today and started the wire brush treatment.
There's a really beautiful anvil under all the rust and dirt.  :-)
I can't find any weight markings on there as of yet.  The sellers thought it was around 300#, and I don't think that may be too far off.  There's a pic comparison of a 225# Trenton next to this Columbian.  Visibly beefier in every regard.  I'll get my 300# scale out this week for a better value, maybe it'll bottom the scale out.....
post-25745-0-53071300-1369012162_thumb.j
post-25745-0-94177400-1369012174_thumb.j
post-25745-0-40146300-1369012187_thumb.j
