Aspery style stakes
I'm finally taking some time in the shop to makle some stuff for me. I made the stakes from Mark Aspery's book today. Made them from S7-mainly cause it's what I have. Next is good news/bad news thing. 2 of them failed-mostly because I mistreated the material. I forged it like plain steel-when drawing the tapers, I had the problem an uneven taper-one side a bit thicker than the other-due to the dies being worn in my hammer. So, I did what I do with mild steel (duh-not the thing to do)-stood it a bit on the diamond to knock one side down. If you look at the resulting crack you can see exactly  what happened. Step one-plug in brain-then work. Remade 2-was careful in forging-results were very nice.
post-1460-0-46772900-1368405693_thumb.jp
post-1460-0-99923900-1368405904_thumb.jp
