S.Hollowood Posted April 30, 2013 Share Posted April 30, 2013 Just want to share the news and my excitement. I just got the last of money i needed to order my belt grinder. Email sent out, now i can't wait. I decided upon the Coote with a 10" wheel, and a glass platten. Found out one of my friends has the machine and can't be happier with it, even after using promachines at a local hammer in. I have used it before, and liked it, after researching for the past year or so, and doing all of the work with a cheap 4" by 36" belt sander, i figured it was time. Thanks for all the help you guys, and this forum have given me! Link to comment Share on other sites More sharing options...
Fe-Wood Posted April 30, 2013 Share Posted April 30, 2013 Looks like a nice grinder set up! Congrats! Link to comment Share on other sites More sharing options...
Loneforge Posted May 1, 2013 Share Posted May 1, 2013 I run a Coote myself. I set mine up with a treadmill motor with variable speed drive. Works great......I think. Enjoy! Link to comment Share on other sites More sharing options...
Don A Posted May 1, 2013 Share Posted May 1, 2013 Darren, Forgive me if I've asked this before, but a Coote with a DC treadmill motor is on my revolving, ever evolving, to-do list. I've stripped out a motor, but I haven't bought the grinder yet. That said, did you scavenge the variable speed from the treadmill, or did you buy a new unit? How complicated was it to get the motor running like you wanted it? Any thing you'd do different? Thanks, Don Link to comment Share on other sites More sharing options...
Loneforge Posted September 27, 2013 Share Posted September 27, 2013 Sorry Don.....haven't looked back at this thread for a bit. We simply replaced the motor from a table saw.....Used table saw is my grinder bench.....Replaced the blade with a pulley and mounted the grinder on the Saw deck. We stepped the whole ratio down 4:1 as the top speed on the treadmill motor was 6000RPM. This allowed us 1500RPM on the drive wheel. Only thing I would do different is not using V belts as they offer a bit of vibration at various speeds.....And make good and sure you keep the motor and circuit board dust free.....Burned one circuit board by allowing grindings in. Hope this is not way too late and have fun! Link to comment Share on other sites More sharing options...
Dan C Posted September 27, 2013 Share Posted September 27, 2013 How are you isolating the motor & board from metal dust and still allowing air flow for cooling, maybe just a shield? Link to comment Share on other sites More sharing options...
Loneforge Posted September 29, 2013 Share Posted September 29, 2013 We put the board in an old 100 AMP circuit breaker case and used part of the plastic casing from the treadmill body as a shield to keep grinding from entering the motor. Link to comment Share on other sites More sharing options...
gearhartironwerks Posted October 8, 2013 Share Posted October 8, 2013 I run a Coote myself. I set mine up with a treadmill motor with variable speed drive. Works great......I think. Enjoy! After seeing your blades, I'd say you and your Coote work pretty well...together. :) John Link to comment Share on other sites More sharing options...
Loneforge Posted November 5, 2013 Share Posted November 5, 2013 The Coote attached to an old Rockwell beaver table saw. this was during build and now has proper guards in place to protect motor and circuitry. Link to comment Share on other sites More sharing options...
BCROB Posted November 6, 2013 Share Posted November 6, 2013 The Coote attached to an old Rockwell beaver table saw. this was during build and now has proper guards in place to protect motor and circuitry. '> Link to comment Share on other sites More sharing options...
blacksmith-450 Posted May 5, 2018 Share Posted May 5, 2018 I just bought mine with a 8 inch. contact wheel. I'm going to put a 2hp engine with stepped pulley on the engine and the grinder. That should give me 6 speeds. I will put pictures later. I want to highlight the excellent customer service at Coote. Thank you Norm! Link to comment Share on other sites More sharing options...
Please sign in to comment
