first blade
flyyoufool
Forged from 5/8"x1/4" flat steel bar I found in a scrap pile. I have no clue about the composition. I just started hitting it with the hammer, saw where it was going, and started reading and watching videos. My approximation of a habaki is made of a piece of AC tubing I found in said scrap pile. I had the little piece soldered in, but i ground it too far and split it. So I filled it in with the tig instead. My approximation of the saya and tsuka are made of part of a pallet leftover from a chest I built. I also made these chisels when I found out how difficult it is to accurately carve out wood with a knife.
I had it all clayed up before I realized that my forge wouldn't keep enough of the length hot enough to actually harden the whole blade. After a few attempts between the forge and O/A I decided to just try to harden the tip. I got as much of the tip as hot as i could get it and water quenched. I cleaned it up and heated it til it turned blue. Im not 100 percent sure it hardened. It felt harder when i ran a file across it, but I haven't tried a different way to tell. I think someone said something about soaking in vinegar..
After too much time filing and sanding and sanding and sanding in an attempt to remove the scrapes caused by irresponsible filing, I decided to go with angle grinder with a tiger paw. So here we are. I'm moving on to the next one because I want to focus more on forging, I want to re-heat treat it, and I used up all of my sandpaper...
post-39375-0-50963800-1366857437_thumb.j
post-39375-0-94080200-1366857444_thumb.j
post-39375-0-59092700-1366857454_thumb.j
post-39375-0-92180700-1366857462_thumb.j
post-39375-0-92126400-1366857480_thumb.j
Not bad. I tested my first couple of blades to destruction. One way to find out if your heat treating worked. Although it does suck to put a lot of energy into something just to watch it break but that's how I found out that I wasn't tempering well enough
