andys MQ Posted January 21, 2013 Share Posted January 21, 2013 Hi all so just getting things started and have made a pair of tongs and a very dodgy punch for the rivet in the tongs. But not sure what to make next i think maybe a hot set for the hardy. And of course I will make more tongs. What do you use the most ? Only really interested in tool making at the moment. So, what do you reckon? What next? Quote Link to comment Share on other sites More sharing options...
Timothy Miller Posted January 21, 2013 Share Posted January 21, 2013 Hot cut hardie, bending forks, spring fullers, rivet sets, punches, chisels, anvil bick the list goes on and on. Quote Link to comment Share on other sites More sharing options...
andys MQ Posted January 21, 2013 Author Share Posted January 21, 2013 Yer bending forks sounds like a good idea as I use coil springs from a car for my tongs and such. Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted January 21, 2013 Share Posted January 21, 2013 Hardy is a good tool to have, very handy. Holdfast is another good one, could even be made from scrap rebar. An anvil helper is a good option, helps for punching holes. Veining chisel for making leaves, More tongs are always welcome in a shop, and many sized punches are always useful. Bending forks, as already mentioned are very easy to make for a vise, just use a piece of round stock bent into a U shape. Flux spoon if you are going to be fire welding anytime soon, fire tools, handled hot cut, slitters and drifts, small set hammers, riveting cross peins, hand fullers made from ball peen heads, flatters (if you weld), as well as all already mentioned. Make it, review it, make it better, and soon you'll have a shop full of tools, and a head full of knowledge! Quote Link to comment Share on other sites More sharing options...
GRiley904 Posted January 21, 2013 Share Posted January 21, 2013 You say very dodgy punch, maybe make another and polish that skill Quote Link to comment Share on other sites More sharing options...
andys MQ Posted January 22, 2013 Author Share Posted January 22, 2013 Yes I will for sure:-) was just in a rush to make the tongs work. Might have to search for how to forge a taper, the one I did was just with my hammer and a bit rushed so is sort of all over the place Quote Link to comment Share on other sites More sharing options...
GRiley904 Posted January 22, 2013 Share Posted January 22, 2013 Look up Brian Brazeal on you tube. He is an experienced smith and has some great videos out there including one on how to forge tapers Quote Link to comment Share on other sites More sharing options...
Ridgewayforge Posted January 22, 2013 Share Posted January 22, 2013 For tongs you can also drill the rivet hole. Taper square, octogon, round, square, octogon, round. (I usually skip the round until the end. It still works.) Also, use the horn to draw out metal faster. Quote Link to comment Share on other sites More sharing options...
