62inlongbow Posted December 26, 2012 Share Posted December 26, 2012 how do you get the weeping heart in a tomhawk? Link to comment Share on other sites More sharing options...
ptree Posted December 26, 2012 Share Posted December 26, 2012 Drill or punch an access hole then cut with a jewlers saw. Link to comment Share on other sites More sharing options...
62inlongbow Posted December 26, 2012 Author Share Posted December 26, 2012 thanks, I thought there might be a way other than useing a saw. Link to comment Share on other sites More sharing options...
781 Posted December 26, 2012 Share Posted December 26, 2012 You could try a punch but drilling then file grind and or saw will be much cleanerIf you are filing not sawing drilling 2 larger holes for the top of the heart and one or more smaller for the middle bottom ect then clean up with a dremil or files Link to comment Share on other sites More sharing options...
macbruce Posted December 26, 2012 Share Posted December 26, 2012 Keep in mind.....When a jewelers saw blade breaks (and they will) it throws bits of broken blade with such velocity they sound like a bullet ricochet! Wear em.... B) Link to comment Share on other sites More sharing options...
KYBOY Posted December 26, 2012 Share Posted December 26, 2012 here is a mjolnir cutout we did in a hawk for a customer...Hot cutting or drilling, then files to shape.. Here is a deer track done the same way.. Link to comment Share on other sites More sharing options...
MOblacksmith0530 Posted December 26, 2012 Share Posted December 26, 2012 Sweet looking hawks Link to comment Share on other sites More sharing options...
KYBOY Posted December 26, 2012 Share Posted December 26, 2012 thanks Link to comment Share on other sites More sharing options...
ptree Posted December 26, 2012 Share Posted December 26, 2012 My experience with jewlelers saws is that when they break they give a little ping and that is it. Never had one send shards, but then I was trained in Germany, using high grade German blades and still use those now, 30 years later. I also tend to use the very fine blades only and they are very very thin. Link to comment Share on other sites More sharing options...
macbruce Posted December 26, 2012 Share Posted December 26, 2012 My experience with jewlelers saws is that when they break they give a little ping and that is it. Never had one send shards, but then I was trained in Germany, using high grade German blades and still use those now, 30 years later. I also tend to use the very fine blades only and they are very very thin. My experience is that I've heard broken bits of blade wizz past my ear.........Wear em..... ;) Scroll to the bottom of this link. http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=8&cad=rja&ved=0CHoQFjAH&url=http%3A%2F%2Fwww.wikihow.com%2FUse-a-Jewelry-Saw-to-Cut-Jump-Rings&ei=dIPbULLjDIHQiwKVhIDADg&usg=AFQjCNEw_1ghpbv9HzHPafMvVj6jAFGrtg&sig2=Nzy59BXQojgwUikg8vdjJw&bvm=bv.1355534169,d.cGE Link to comment Share on other sites More sharing options...
Bentiron1946 Posted December 27, 2012 Share Posted December 27, 2012 McBruce, So you like your blades a little on the taut side, I usually just make them tight enough for a nice ping when plucked by my fingernail. Of course I have one friend that, like you, makes them really, really tight. How tight? You don't want to be in the same room when the the blade breaks unless you have on a full face mask for sure. Link to comment Share on other sites More sharing options...
macbruce Posted December 27, 2012 Share Posted December 27, 2012 McBruce, So you like your blades a little on the taut side, I usually just make them tight enough for a nice ping when plucked by my fingernail. Of course I have one friend that, like you, makes them really, really tight. How tight? You don't want to be in the same room when the the blade breaks unless you have on a full face mask for sure. I haven't used one in a long time and I did some decent cutting with them, no problem. I just remember the sound of that teeny bit of blade going by my ear and and I figured it had to be really moving to make it.....Before that I never wore glasses when using the jewelers saw but that incident made a believer outa me. Link to comment Share on other sites More sharing options...
62inlongbow Posted December 27, 2012 Author Share Posted December 27, 2012 nice hawks Kyboy,I really like the hoof print.thanks for all the help everyone Link to comment Share on other sites More sharing options...
Camulus777 Posted April 1, 2018 Share Posted April 1, 2018 I know that this is a prety dead topic but I made a heart shaped hot punch that works great so all that you have to do is a tiny bit o cleanup. Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted April 2, 2018 Share Posted April 2, 2018 Never hurts to revive an old thread with new information. I like your idea of a heart shaped hot punch, another why didn't I think of that. BTW @Camulus777 Welcome to IFI. Have you read this thread. It contains a lot of good info on using the forum. Link to comment Share on other sites More sharing options...
Camulus777 Posted April 2, 2018 Share Posted April 2, 2018 13 hours ago, Irondragon Forge & Clay said: spam removed Thank you so much. I've recently gotten into more knife and blade making in my shop now that I have some extra hands making my architectural stuff and rings. I figured I'd come here and consult the experts. What a wonderful thread. If you had read that you would have known enough to not spam us with a repeat of what we just read, stop wasting bandwidth re quoting when its not needed Link to comment Share on other sites More sharing options...
Please sign in to comment
