bogmonster Posted November 22, 2012 Share Posted November 22, 2012 Hi, I am in the process of building a forge. I have a single burner at the moment. I got my burner from here http://www.devil-forge.com/burners/DFP%20-%20burner.htm. I will probably add a second burner with ball valves so I can choose to run only one if I want. The body is made from a pile of bricks with insulation bricks and heavy bricks on the floor. I have only had one test with the burner side mounted. I didn't have long to play but my steel was not getting up to forge welding temp. The regulator I have is 0-4 bar and the burner is only rated to about 1.75 bar so I didn't open the regulator all the way - there is no gauge on it. One change I will make is to replace the regulator with one that has a gauge and tops out at 2 bar. I have borrowed the regulator from something else anyway. What is likely if the pressure is too high? Will it just burn rich? So a couple of newbie questions? Coating the bricks with something like ITC 100 should help but I can't find this or similar in the UK. Any ideas on a suitable product with a distributor in the UK willing to provide low quantities? Also, how far does this stuff go, will I need multiple coats etc? Presumably having the steel directly in the flame jet will help get it to welding temp. for this I could try angling the burner from the side or go in from the top. At the moment the jet is horizontal and an inch over the steel. Alternatively I could add another thin brick to raise the steel a bit? Any suggestions? I know this might be hard to visualize so will try and get some photos at the weekend. Also picking up an anvil at the weekend (well, one and 3/4 anvils really, one has a broken heal but was very cheap). I think I have a steep leaning curve ahead.... I won't be trying forge welding straight away, I am starting at the beginning so need to learn to walk first. Oh, my first project is not a sword :) In fact I don't think I will ever want to make a sword.... BW BM Quote Link to comment Share on other sites More sharing options...
bogmonster Posted November 22, 2012 Author Share Posted November 22, 2012 Doh, just read the specs again, burner goes up to about 3.4 bar... maybe I need to crank it up a bit more :) Quote Link to comment Share on other sites More sharing options...
