Laertius Posted November 3, 2012 Posted November 3, 2012 As I said In my post in the solid fuel forge section I am new and just in the 'setting up' phase. I have learned a lot from this and other forums and look forward to your comments / suggestions. So here is the story: I started out with a couple pieces of crane rail-- not the most fun, but workable. Then I got a nice piece of 'real' rail, already cut roughly into the shape of an anvil - so I thought score, now I can make one like the one on anvilfire (vertical peice for mass under hammer + horizontal for lighter work.) You can see this one in the first couple of pics, I like it cuz I built it but in all fairness, it is not half as functional as the one I just bought. The second set of pics are my score from an older gent who was selling off some stuff. They were not his, but came from his property -- 40$! with the stand! It is a 'attwood stourbridge - best - 84 -h k - At least those are the markings -- ANY INFO ON this anvil would be greatly appreciated: Date, weight etc! I think it is more than a hundred lbs.....but I may just be overguessing as the stamp that says 84 could very well be the weight.... I have done the ball bearing hardness test on both (1" ball from ten"): The rr horizontal is around .25 or 30, the vertical section is about .40 and the Attwood farrier's anvil is about 75-90 depending on where I hit it -- IT has a great ring and no visible cracks.. So DO I keep'em both? Will I ever use my creation now that I have the 'real' one? Quote
jimmy seale Posted November 3, 2012 Posted November 3, 2012 yes keepem both, you'll be surprised at how handy they can be,the rail will sure be easier to carry around if needed. can't say anything about the attwood, but i'm sure some one here will know something. Quote
John McPherson Posted November 3, 2012 Posted November 3, 2012 Attwood was a fine old English anvil maker, but the 84 is not the standard hundredweight measuring system. It is not marked 'England' like it would be if made for the American market after a certain date, don't know if they ever had to do that for the Canadian market. Quote
K. Bryan Morgan Posted November 3, 2012 Posted November 3, 2012 I agree with Jimmy, keep them both. I started on a railroad anvil and still use it. For small things its perfect. I would grind the "horn" area to a little more round and get rid of those rough edges in that area. I use my horn on my rr anvil for small rounds because my large anvil horn end in a 1" blunt point. So, its perfect for little things like that. Quote
HWooldridge Posted November 3, 2012 Posted November 3, 2012 Stourbridge is a traditional ironworking area in England and was the home of Stourbridge Ironworks. I've had the priviledge of visiting the area and seeing the "Iron Bridge" - the first cast iron bridge in the world. Doesn't surprise me they made quailty anvils. Quote
Laertius Posted November 5, 2012 Author Posted November 5, 2012 Thanks For the information guys! I will let you know how it works over the coming weeks, but I am quite happy with it overall! Quote
Laertius Posted March 10, 2014 Author Posted March 10, 2014 Resurecting an old thread. I have been smithing now here and there in the evenings and weekends, and wanted to upsate my first posts. See the attached pics for my completed rail anvil, and he atwood on the modified (since i bought it) stand it came with. I like them both, and will prob have them forevever even after I acquire a big double horn and or a striking anvil. Thanks again for all great knowledge on this site, Quote
