Azur Jahić Posted September 26, 2012 Share Posted September 26, 2012 What is simleast way to make bellows and forge and cheap Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 26, 2012 Author Share Posted September 26, 2012 can i make some change of my bellows i diassembled my bellows and i was thinking to get on space and remove up inner tube can i put 2 inner tube down or 3 or more and shut hole in place when was up inner tube Quote Link to comment Share on other sites More sharing options...
Maillemaker Posted September 27, 2012 Share Posted September 27, 2012 Step One: Dig hole in ground. Step Two: Insert air pipe/tuyere. Step Three: Start fire. Blow into pipe for air supply. That's about as cut-and-dried as you can get. Quote Link to comment Share on other sites More sharing options...
jmccustomknives Posted September 27, 2012 Share Posted September 27, 2012 Brake drum forge, little wet/dry vac for air. If you've got real good coal a hair dryer will make a good enough fire ball to do most smaller work. I saw a pic in one book where a guy used an old grill (one of those cheap round/shallow types) with a hair dryer piped in the side. Cheap or free is my motto. Quote Link to comment Share on other sites More sharing options...
Brasilikilt Posted September 27, 2012 Share Posted September 27, 2012 Watching this certainly gave me some ideas if ever I decide to forge during a campout or something. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 27, 2012 Author Share Posted September 27, 2012 can i make bellows like this using something instead leather and how is name this bellow on video Quote Link to comment Share on other sites More sharing options...
Maillemaker Posted September 27, 2012 Share Posted September 27, 2012 The bellows can be made of leather, heavy canvas, treated cloth, or any other flexible, air-tight material. I've seen bellows made from inner tube rubber. Quote Link to comment Share on other sites More sharing options...
David Einhorn Posted September 28, 2012 Share Posted September 28, 2012 You can also use second-hand rubber roofing material, as well as fake leather type upholstery material. You can also take canvas and paint or spray it with "tool dip". Personally, I am biased as I much prefer traditional type bellows. Cost depends on your ability to scrounge.http://www.facebook....35399321&type=1 Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 28, 2012 Author Share Posted September 28, 2012 it somebody have idea how to make bicycle powered fan for forge Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 29, 2012 Author Share Posted September 29, 2012 do you try to use spray on fire can i make that forge just light the fire and spray it will i get a need temperature is that a dangerous Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted September 29, 2012 Share Posted September 29, 2012 Azur I can only imagine how hard a time you are having trying to get this set up working for your shop. I am so spoiled that If I were beginning I couid get on this site and poull up a design that has instrutions and find the needed materials locally. Non of that is working for you at all it seems. When someoone suggests something for you to try, it is likely based on things they know are availeable here and can be done with tools and skills they have or can get locally. When I think of how to help you it is based on those things I just typed. You live in a totally different life style than I do and I do not know how to fit wot I know into things that will work for you. I wish I could. i hope that someone can work with you on this and would love to see you with a working forge. Youi really seem to have the interest it takes for this work..Good luck. Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 29, 2012 Author Share Posted September 29, 2012 i have ply wood some sheet metal bicycle rear and front wheel old bicycle frame wood stick and i was thinking to make some blower like hand crank just powered with bicicycle Quote Link to comment Share on other sites More sharing options...
John B Posted September 29, 2012 Share Posted September 29, 2012 Hi Azur, have a look here, at box bellows, Plywood and a wood stick and a bit of carpet , there are also links to further details on how to make them in the comments beneath the videohttp://www.youtube.com/watch?v=fwJ2mCv0Lls&feature=related Quote Link to comment Share on other sites More sharing options...
Azur Jahić Posted September 29, 2012 Author Share Posted September 29, 2012 i tried but it have a much hole i dont have enaugh skills for this job :o i had too much hole for air and it look like this Quote Link to comment Share on other sites More sharing options...
