mat Posted August 30, 2012 Share Posted August 30, 2012 i found a big bit of plastic in a bin,is there a way of knowing if its uhmw or not?there was plaster board,kitchen cabenets,shop fitting hard wear,also in the bin which makes me think yes.i have never used uhmw so cant compare it.its 20mm thick,the pic has a 12" ruler for scale.it flexes dents and has a waxy slippy feel to it. Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted August 30, 2012 Share Posted August 30, 2012 It's probably HDPE. UHMW typically does not feel as "waxy" as the lower density materials. About the only way to know with some certainty is to cut a 1" square cube and determine its density. Quote Link to comment Share on other sites More sharing options...
Will. K. Posted August 31, 2012 Share Posted August 31, 2012 There are different grades & types of uhmw as well. Quote Link to comment Share on other sites More sharing options...
mat Posted August 31, 2012 Author Share Posted August 31, 2012 thanks Quote Link to comment Share on other sites More sharing options...
bigfootnampa Posted August 31, 2012 Share Posted August 31, 2012 UHMW has always seemed pretty slippery to me. We used it to line the 1 3/4" hose beds on our fire trucks when we switched to rubber coated hose specifically to make it easier to pull the hoses out... the rubber coatings were sticky against the old metal hose bed sides. Either way it will likely work okay for whatever you have in mind though. Quote Link to comment Share on other sites More sharing options...
